Home | Danby | DDR583R Dehumidifier | DEHUMIDIFIER | ADR556RH
Danby DDR583R Dehumidifier
Problem for Danby DDR583R Dehumidifier
By jayjay1 on Sep 07, 2007
I have a ADR556RH whats the Efficiency Factor (EF)?
Best Solution
posted on Sep 08, 2007
Very Helpful)
Krazytech
Rank: Guru
Rating: 90%, 635 votes
The Efficiency Factor (EF) is a guide to a dehumidifier's operating cost.
The EF is the amount of water, in litres, a dehumidifier removes at 27°C (80.6°F) and 60 per cent relative humidity for each kilowatt hour (kWh) of electricity. If electricity costs 8 cents a kilowatt hour, which it does in many parts of Canada, a unit with an EF of 1.2 will remove 15 L (32 U.S. pints or 3.3 imperial gal.) foreach dollar in electricity costs. An advanced unit with an EF of 2.4 will remove 30 L (63 U.S. pints, 6 1/2 imperial gal.) of water for each electrical dollar spent.
Because condensation gives off heat a dehumidifier acts as a heat source. This can be useful in spring or fall, when basements tend to be cool. In mid-summer, the heat added by a dehumidifier is counterproductive.
Was this helpful?
Yes
No
Popular Solutions for Danby DDR583R Dehumidifier
Questions and Unsolved Problems for Danby DDR583R Dehumidifier
Do you recommend Danby DDR583R Dehumidifier?
Answer
Answer
After a lengthy period of inactivity, we came to use the dehumidifier and noticed that the LED... (More)
Answer
I have been emptying the tank few times a day, because I had no convenient drain in basement. Now, I... (More)
Answer
Model DDR6588EE - called Danby and they will not tell me what part I need or how I can order it due... (More)
Answer
My unit is collecting moisture VERY WELL! BUT it blows warm air only which makes it very hot in our... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR583R Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
