Question about Protron PLTV-37 37 in. LCD Television
Lcd tv "shadows"
I am trying to figure out what is possibly wrong with this tv. It was moved the yesterday, now when it is turned on, it works, however, there are "shadows" or some kind of spots in the viewing area. Thanks for any help!
  • 2 more comments
  • marika Nov 25, 2007
    we have a new protron and now we have a huge dark green 3 inch wide line going down the right side of the screen. now what?
  • Anonymous Jan 27, 2008
    we have the same "shadow" problem on the right side of our tv.
  • deananj Jan 27, 2008
    we have the shadow problem too. looking for help!!
  • Anonymous Feb 10, 2008
    just show a diferent color views and color bars
I think there just poorly made crap t.vs
Posted on Dec 11, 2007
Dark shadow on samsung lcd tv
shadows being left when turning sumsung lcd television over
Feb 25, 2010 | Samsung TXR3079 TV
'Shadows' behind all texts and images on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
Mar 16, 2009 | Philips 47PFL7403D 47 in. LCD TV
Shadows
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blurry and shaking pictures on LCD
refresh rate, likely
try to adjust to a compatible rate. the monitor manual will give you its compatible rates. the video card should have that rate available. if not, you may damage the monitor with the wrong rate.
stop and try another monitor that has a refresh rate available on your video card.
good luck
mark
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Protron PLTV-37 37 in. LCD Television Logo
165 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
