Question about Alps MD 2010 Thermal Printer
Printer strats but does not print
I am trying to print on my md 2010 but the printer starts and loads the paper but when it is time to print the printer just stops. any ideas???
    New Friend:
  • 83 Answers
There could be a loose connection on the power supply. I can a similar problem with my 2300. Make sure all the connections are tight and clean the PS with compressed air.
Posted on Jun 28, 2010
SOURCE:
Is there a way to determine the number of pages an Alps MD-1000 has printed, like a mileage gauge on a car.
Yes. It's very easy. Turn the printer off, unplug it, and disconnect the printer cable. Insert two sheets of paper, and make sure the paper feed is set to automatic. You need to have a black cartridge loaded into the 1st slot.
Plug in the printer and wait for the lights to turn off. Press and hold the power button at the same time press and hold the "ready/Insert" button. Release the power button, but keep holding the "ready/Insert" button for at least 4 seconds. After 4 seconds, release the "ready/Insert" button and quickly press it again. The printer will start the selftest.
For the 1300, the number of bands printed will be on page two. On the 1st page, there will be a black bar on the bottom of the page. It should be a solid black bar with no lines - this is the test for bad elements on the print head.
Aug 29, 2011 | Alps MD 1300 Thermal Printer
ALPS MD 5000 thermal Printer loads paper but only spits it out when I press print then loads the next
Do you have the right cartridges in the printer? The dark gray is for regular printing.
Jul 01, 2011 | Alps MD 5000 Thermal Printer
How to test the MD 1300 , also look on how to get error codes...
One test you can run is the self print test. Discount the printer from your computer. Load a single sheet of paper and the CMYK cartridges. Turn on the printer. Press and hold the "reset" button until the lights begin to flash. Release the "reset" button and the printer should do a self print test.
Dec 26, 2010 | Alps MD 1300 Thermal Printer
Diagnostics Mode
you can find that at their website, under tutorials or get the user guide there.
Aug 19, 2008 | Alps MD 5000 Thermal Printer
Printer will not print from file
The spooled files are not getting to the printer, do the following in sequence:
Start checking usb cable, test it by using a different one.
Check that no device close to usb can create an electromagnetic disturbance, a power adapter can do this.
Disconnect printer from power, Computer from power (unplug cables form power outlet) and printer from computer for 10 minutes (this will reset printer and get rid of electrostatic charges on PC usb).
Connect everything back and try.
If none of the above worked disconnect printer from usb,
remove printer from 'installed printers' in Windows (or whatever OS you are using)
Reinstall driver from printer disk (printer must remain unplugged).
Plug back printer only when required from printer software or after driver setup.
If it still does not work it may be a problem with heads, Alps are quite peculiar printers, in this case you will need to find a servicemen in your area.
Regards
Apr 23, 2008 | Alps MD 1000 Thermal Printer
Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
Apr 22, 2008 | Alps MD 1000 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
The printer starts to print but no print
a friend of mine had the same problem and after 28 h of searching ist was clear, that not the printer is damaged. No. Windows had made its online Updates (Service packs) and from then on printing failed. Try to reset your Windows OS to the date, when the Alps worked properly and i think it will work again. I can give you no fo further Information about windows settings, sorry i`m a Mac user.
I dont have these kind of Problems. Think about it !!!!!
Greetings from Germany
Sep 07, 2007 | Alps MD 2010 Thermal Printer
Alps MD 2010 Thermal Printer Logo
87 people viewed this question
Top Alps Office Equipment & Supplies Experts
Clive
Clive
defcon000001
Level 1 Expert
Jesse Walters
Jesse Walters
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
