Question about i-mate SP JAS Cell Phone
Vodacom gprs settings for i-mate
I have an i-mate SP JAS. I'm not certain what the connection settings should be to enable gprs. (DNS and IP address)
Please help
  • 180 Answers
If you are with Vodacom, just dial *111# , select “Device Setup” and follow the instructions.
Name APN Username Password Primary DNS
Vodacom internet None None 196.207.40.165
Secondary DNS
196.43.46.190
1. Try leaving out DNS addresses first. DNS servers are usually assigned automatically to your device on connect.
2. If you are using Vodacom and GPRS does not want to work, first call customer support and make sure your sim is activated for the “internet” APN.
Posted on Jun 20, 2010
SOURCE:
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
C:\Users\Nelson>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : Dragonlorde Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP...
It does not show as connected. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done! Test it with network cable to pc before trying a wireless device.
Default IP is 192.168.1.1 Use web browser to access. User: Admin Password: password.
There is reset option in the back. Hold it in till it cycles. This will clear all custom settings.
http://www.netgear.com/images/WNR3500Lv2_DS_07Jun1118-5898.pdf
Nov 08, 2012 | NetGear WNR3500L100NAS Rangemax WirelessN...
Can't connect to router interface 192.168.1.1
Took another look by fixing word wrapping in notepad.
It's missing DNS Servers. Check your NIC settings and make sure you don't have a DNS server manually set to another IP. Plus, you might try resetting the router to default in case there is a DNS modification there.
I'm not sure if this is the cause, but I couldn't hurt. It's part of trouble shooting.
Good Luck!
JD
Oct 02, 2012 | Computers & Internet
Could someone pls help me to configure my Samsung GT-B7722. My network Sun Cellular (Philippines) says they do not have the setting for my phone model. Thank you!
Since Sun Cellular does not have specific settings for your phone for an automatic configuration, you can still connect to the internet by configuring your device manually. You just have to look for internet settings in your phone and input the configuration as indicated below.
SUN GPRS Settings (HTTP & WAP)
Connects to:The Internet
Access Point:minternet
User & Password :
Primary DNS:210.23.234.65
Secondary DNS:0.0.0.0
IP Address:
SUN MMS Settings
Connects to:MMS Connection
Access Point:mms
User & Password :
Primary DNS:0.0.0.0
IP Address:
Go to programs-accessories-MMS Setup
MMS Connection
IP:202.138.159.78
Port:9201
Mmsc Address:http://mmscenter.suncellular.com.ph
MMS Download:Auto
Mar 22, 2011 | Samsung SGH-D900 Cellular Phone
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
I can not access gprs in nokia 7610 opretor is vodacom so pl. can u give me the manual setting
Seconday DNS
196.43.46.190
Feb 24, 2010 | Nokia 7610
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
Gprs settings
for gprs setting, first add new mdem connection, then tap manage existing connection , then set ip setting as 10.4.42.15 for more details visit ideafresh.com
Apr 01, 2008 | i-mate Pocket PC
i-mate SP JAS Cell Phone Logo
261 people viewed this question
Top i-mate Cell Phones Experts
Marvin
Marvin
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
