Question about Samsung SGH-E900 Cellular Phone
Remove front screen
Broken lcd also casing around screen
Posted on May 25, 2008
Look up www for diagrams on how to fit and manuals
Posted on Dec 24, 2007
  • 33 Answers
I think NickBeamAA is right. Also you need a soldering iron to do this. Normally it costs about 40pounds (New flex cable, LCD and work).
Posted on Sep 26, 2007
    New Friend:
  • 53 Answers
The cheapest way would be to order good used replacement parts, ebay is probably your best bet. Once you've gotten the parts i can email you a link to check out for disassembly. The best way would be to have a service center check it out and quote you a price, but it will be quite a bit more expensive. However it will be professionally done so there is far less chance of any other damage being done.
Posted on Sep 07, 2007
  • Nicholas Burress
    Nicholas Burress Sep 13, 2007
    Is there any more information i can give you??
How to change glass screen o 10.1 trio stealth 2g tablet
The screen replacement is available at Amazon. As stated in the description, no instructions included. Nice set of tools included; most not needed. Installation is pretty intuitive; once you see the new screen, you realize that it attaches to the front bevel with adhesive tape, with one electrical connection. You must remove the broken screen basically by gently prying around the edges with tool of your choice. I did see a video of someone using a heat gun to soften the adhesive, but I dared not and used a small hairdryer on occasion. Lots of broken glass pieces will be created, wear safety glasses and work on a protected surface. If I were to do it again, I'd use a shallow cardboard box like the ones on the bottom of packs of soda. This will prevent glass escaping. Be VERY careful when working near the LCD screen, it does scratch easily. Don't worry about the cable, just cut it when removing old glass. Once all glass removed, the Trio will snap open with slight pressure on metal tabs. NO screws involved. Clean bezel well, remove old cable, install new one , reinstall the power and volume piece at the top and snap case together. Simply replace screen by removing adhesive tape and gently pressing screen it in around edges. I think the new screen works better than the original. Be sure both new screen and LCD are clean before the final install. That's how I did it; others might have a better way. Be patient and careful about all the broken glass and it should work fine. Good Buy for money, ships from China but does not take long to get to US. Tracking info is included with the shipping confirmation.
Oct 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
My screen on my toshiba laptop P775 comes on but looks broken
If you mean broken as in it has a crack, it has liquid effect leak or dark then yes you have a broken lcd
Replacing is not a difficult as it seems, mainly by removing a few screws around the frame hidding under the rubber pads, then sometime you also need to remove the keyboard/power control panel, then its jsut a case of removing the broken lcd and buying a replacement panel and fitting it.
heres me taking a panel out on another laptop but gives you the idea.
If your in London, then I can do the repair for, cost of parts + 20pounds + return delivery costs.
Feb 03, 2013 | Toshiba Satellite P775S7236 Notebook
I want to replace the LCD screen myself but I can't find any video that shows me how. All of them show laptops that screws on the front of the bezzle and mine doesn't. How do I get the bezzle off?
Here's how to remove a screen for a laptop with a front bezzle instead of just front screws:
1. Power down your laptop. Disconnect the power cable and any peripheral devices from the laptop. Close the LCD screen, flip the laptop over and remove the battery from the bottom casing of the laptop.
  • 2.Flip the laptop over, and then open the LCD screen all the way. Remove the rubber screw covers from the front LCD bezel. The screw covers will be located on the front of the panel, or along the side edges, depending on your laptop's make and model.
  • 3.Remove the retaining Phillips-head screws from the front LCD bezel. Insert a flat-head screwdriver into the gap along the outside edge of the LCD panel. Start to pry off the front bezel. Work your way around the entire LCD panel until the front bezel is separated from the panel.
  • 4. Remove the the bezel from the LCD panel and set it aside.
  • Mar 19, 2011 | HEWLETT-PACKARD G72260US Notebook
    Our screen is broken may be because foot rested on the screen. How do you take out the screen so that a new one can put in.
    Disassembling a laptop is not something that you should "try" by yourself.
    If you accept the risks:
    * make a "backup" of all your files, just to be "safe"
    * turn the computer off
    * disconnect the AC power
    * remove the battery
    * remove the covers over the hinges
    * remove the keyboard -- note that a DELICATE "ribbon-cable" connects the keyboard to the case
    * remove the top-plate -- by unscrewing some of the screws on the bottom of the case
    * unscrew the hinges -- note that a DELICATE cable connects the LCD to the case
    * remove the "surround" from around the screen
    * swap the screens
    * reassemble.
    Good luck -- you CERTAINLY will need it.
    Dec 24, 2010 | Computers & Internet
    I need to change my screen its broken
    I've swapped out literally hundreds of lcds and it's always the same deal.
    Remove all the screws from around the lcd outer casing, remove the plastic frame, remove the next row of screws, unplug the lcd cable to the lcd, find the part numbers on the back of the lcd and find an exact match on ebay.
    If you search by that part number usually you'll save big time since most people will typically type: nc1502 lcd and the sellers know this so they'll jack up the prices ;)
    Oct 28, 2010 | Everex StepNote NC1502 Notebook
    HP pavilion tx 2130 screen becoming loose on hinge, in open/close movement. (swivel function unaffected)
    In the screen section after remove the front plastic around the LCD you will see some screws holding the LCD display in place. Sometimes these get loose over time. If you can locate and remove the screws " usually under little pads or stickers " and pull off the plastic case around the LCD screen " usually held on by some clips as well " you will easily have access to the hinge screws from there just tighten them down and make sure there no broken off the housing for the screen. Then place the front panel back on and screw is back on and you should be good to go again,
    May 08, 2010 | Computers & Internet
    Samsung l200 digital camera screen broken
    Actually, it's super easy to replace the screen. You'll need to order a new one (around 35$, or so). You'll also need a small screwdriver and a small pair of tweezers (actually, eyebrow removing ones will work just fine).
    Before you do anything, TAKE OUT THE BATTERY.
    Unscrew the screws, remove the front and back casing. Flip the broken screen out of the holder. Follow the orange conductive ribbon round to the other side of the camera, and using the tweezers, gently tug it out of the printed circuit board.
    Carefully remove the broken screen.
    Take the new one, thread the orange strip back through, and insert it in the PCB slot. Put the lcd screen in it's case, and then put the front and back on, and screw it together.
    Watch out for them screws, their small and tricky. don't let them get away from you!
    There's a number clips on youtube of someone doing this to a similar camera, but not this model.
    This really isn't hard to do, so, yknow, I'd recommend it to anyone.
    Dec 04, 2008 | Samsung L200 Digital Camera
    Put dryer belt on maytag dryer
    generic maytag dryer belt replacement
    type 1:older models by Maytag with lintscreen under door
    • unplug dryer
    • remove 2 screws from under front panel
    • tilt front panel up from the bottom and unclip top
    • remove door switch wires
    • set front panel aside
    • remove front drum retainer 2 screws each side
    type 2:newer models by whirlpool lint screen in top cover
    • unplug dryer
    • remove lint screen
    • remove 2 screws under lint screen
    • with putty knife or other blunt blade
      unclip spring clips at front corners of top panel
    • remove 1 screw each side of front panel 1/2 way from top
    • remopve door switch wires
    • tilt front panel down and unclip
    • withdraw drum forward
    • examine drum rollers for wear
      if worn or locked replace in pairs
    • examine felts and nylon glides(if fitted) for wear
      if worn replace
    • examin case floor for tensioner
      (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
    • loop new belt around drum at wear mark of old belt
    • insert drum
    • loop belt around motor pulley
    • pull tensioner to end of travel against spring
    • loop belt around tensioner
    • relax tensioner
    • rotate drum by hand to make sure belt wont jump off
    reassemble in reverse order
    Oct 29, 2008 | Maytag Dryers
    Broken screen
    replace the lcd..
    Apr 07, 2008 | Nokia 6288 Cellular Phone
    How to open the cam gently?? And replace LCD??
    Are you sure you can get the parts you need before you go further? To answer you question hidden screws can be under the mem card flap or Battery flap But I fear you wont be able to repair it. How broken is the screen?
    Aug 27, 2006 | Canon PowerShot SD700 IS Digital ELPH /...
    Samsung SGH-E900 Cellular Phone Logo
    134 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
