Question about Furuno NavNet vx2 GP1720C GPS Receiver
Screen goes blank starts to beep
Today while fishing the unit started to beep after 1 hr being on. When I looked at the screen it was blank and then it would show some lines then blank again. It is a navnet GD-1700c. I turned it off and the picture came back, but after a couple of minutes it did it again. I left it off for about an hour. Turned it on, saw the correct screen, then went off again. It would beep when the screen would go blank. It's about 3 months old.Thanks
2 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: furuno le 6000 turns off imediatly after it is
probably receiving 10-11 volts, check for good power at the cable end where it plugs to the unit
Posted on Jan 13, 2010
It was staying on for about 6 hours then a blank screen. now it comes on to the startup screen and then goes to blank screen.
Same thing happened to my older model. Going to research it today. Mine was on a hot day and Matt have over heated. After recharging the battery it no longer comes on at all. Let me know what you find out if anything
Sep 14, 2015 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
Blank screen
Try this,
turn the unit off, then back on this time holding in the power button until it beeps, a diagnostic screen will come up.
you need to restore this back to the factory so you need to select that option.
After that if you having issue it will need repair I suggest the fols at www.videogamerepair.com simply the best.
Please do be considerate and leave a positive feedbanc and ratings for you free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 29, 2010 | Sony Playstation 3 (PS3) Console
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Blank screen after xp welcome screen no power to keyboard
Ok, with your current set up, what beeps are you getting? Also, while you have a blank desktop, hit CTRL+ALT+DELETE and you'll have Task Manager come up, click File and then New Task and type in "explorer" without quotes and hit enter. That should restore your desktop. Let me know how it goes.
Sep 07, 2007 | Asrock K7VT2 Motherboard
Powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Nov 15, 2006 | Lowrance LCX-19C GPS Receiver
Furuno NavNet vx2 GP1720C GPS Receiver Logo
48 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
