Question about HP PL4245N 42 in. HD-Ready Plasma Television
High Def input search
During any High Def broadcast, when the screen displays any picture that has a bright image,(such as following a golf ball in the bright sky or following a football against the white roof of a dome stadium or many images during a CSI show)the screen goes black and a small ICON appears in the lower right hand corner indicating the TV is searching for an input such as "YPbPr1". After it goes thru it's search mode the picture comes back.
    Sniper:
  • 133 Answers
It sounds like you arent using the correct ports for a HD tv or arent using a HD digital player or HD cable. Still having problem let me know but thats what it looks like to me. Do you have anything plugged into these ports from a HD device? DVD,Digital Recorder, etc?
Posted on Sep 14, 2007
SOURCE:
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 27, 2011 | Apex Digital AT2702 27" TV
Our pitchure is not bright or clear as was in store
This actually common I worked in electronics for 13 years. Did they tell you that it has to be hooked up to an High Definition source. A digital cable or Sattelite reciever does not mean its HD also using Coaxle cableor composite(yellow,red,white) will not produce a good picture. You need HDMI or Component(RED,Blue,Green for video and red white for audio) to get a high def pic. Also not all station are broadcast in high def. One other thing is even if you have a High Def reciever you need to go into the menu of the reciever where it says display and and make sure its set for 1080i or maybe 1080p(most dont have this option yet) If you are using a normal DVD player and use the yellow red and white once again picture will be poor. Need to use Component or hdmi and again with component you need to set DVD to either 480p and if its upconvert to 1080p
Dec 14, 2010 | Vizio VO47L 47 in. LCD TV
We hooked our Sony kp43ht20 to dishnetwork. Now the screen is not full screen. How do we make it full screen again? And where is the ratio button to change to 1080?
Is this hooked to a high definition dish network? If so there is a format button on the remote to change the picture size. As far as changing it to 1080 it will only broadcast in what it sees if it is not in high def it can't broadcast in hi def.
Dec 16, 2009 | Sony KP-43HT20 43" Rear Projection...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Low def pictures on high def flat panel
do you have your video pluged in to the tv or any thing elc if so unplug the video any see if that work or it could be your ampifier let me know how you get on thanks
Jan 03, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
HP PL4245N 42 in. HD-Ready Plasma Television Logo
241 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
