Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
Pc won't turn on
Emachine 410. was left on all day, when i returned i found that pc had switched itself off. when i tried to turn it back on the three lights on keyboard, num lock, cap lock and scroll lock all on and the machine made a funny noise and won't switch on.
Re: pc won't turn on
Same problem. My sons PC was on all night an he noticed several days later when he tried to use it it would not turn on.
I removed the power supply and tried to power it externally but to no avail. I checked the fuse which was still fine.
Does the power supply have some feed back from the mother board in order to start up via one of the harness cables?
emachine 410. was left on all day, when i returned i found that pc had switched itself off. when i tried to turn it back on the three lights on keyboard, num lock, cap lock and scroll lock all on and the machine made a funny noise and won't switch on.
Posted on Feb 23, 2008
I just learned, the hard way of course, that Bestec power supplies, especially the 250w model supplied with desktops by eMachines and some from HP, frequently blow out the motherboard when they fail. Try googling "bestec power supply fail emachines motherboard" (without quotes). No real useful suggestions there, just a lot of ranting about how eMachines and Bestec are crummy, but it gives you an idea of how prevalent this problem is.
Posted on Jan 06, 2008
Power supply failures are very common due to cheap components. PS testers are cheap ( about $5 ) and available on eBay as well as component suppliers. There are many different voltages and connectors coming out of the supply and if any of them are bad your computer may not power up. The testor may show all lines good when the MB connector is plugged in but when you put a load on it ( plug in another connector like the 4 prong drive supply line ) it will fail. There is also a "power good" line on the 20 - 24 pin MB supply that will not allow the MB to power up if values are not in an acceptable range. I recently had a late model Dell Dimension that would not start and the supply tested good with the 24 pin MB connector plugged in - Drive connector plugged in, still good - p4 connector plugged in and bingo - failuire! Replaced the PS supply and all good! Point being that while PS problems are only one of many that may cause a no boot situation, it is the most common and not always obvious.
Posted on Jan 04, 2008
Remove capacitors, big one
Posted on Dec 15, 2007
I sorted the problem and thanks to all that replied. I've bought a new PC! Easily solved.
Posted on Nov 04, 2007
  • 3 Answers
My power supply failed i started tinkerin around with it and found that the connector that goes to the board from the swich, one of the wires where half way pulled out. Found it when i stuck the ohm meter in the back of the conector and it sparked. unpluged it then pushed the wire back into its connector. Pluged the power supply back into the wall Jumped the Green wire to a black ground "all blacks are ground" fired right up
Posted on Oct 23, 2007
You don't need anything except a 300 watt power supply thts all
Posted on Sep 08, 2007
  • 231 Answers
Hi, Are you able to test or repair some of this your self? is so use a multimeter and check the power supply,If you get no reading then remove the unit and open the cover, on the printed circut you will find a fuse either glass or ceramic. Replace this and also clean all dust from the unit replace the cover and reinstall in computer. If this fails you may need a new power supply unit. Regards mistyman
0 characters
3 Points
Emachines eM250: Battery won't charge. Not power cord. Not outlet.
If you do not have a multimeter it will be very difficult for you to figure it out. If you do get back to me and I can help walk you through some steps. Otherwise, buy a new power supply, would not be worth paying someone to fix.
Mar 19, 2013 | System Power Supplies
Lightning storm & power went out for about two seconds. PC plugged into surge protector but would not go back on. Found that surge protector blew and was no good. Got another and plugged all back in...
Your reasoning about the switch mode power supply being damaged is probably right.
Bear in mind that this power supply may not be the only thing that may be damaged in your computer.
You won't know for sure until you borrow a power supply and install it into your computer to see if it will work again.
Jun 18, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Hi. I returned from vacation and turned on my power strip and monitor, tried to start my emachine t5026 computer and got nothing. the power light on the back of the power supply is off. If I unplug or...
Your Power supply is most likely dead.
A power strip is not sufficient protection against black outs, brown outs, power surges and other electrical interruptions that occur in the house. Many PC components are very sensitive to fluctuations in power and power supplies often are among the first casualties when a serious problem occurs.
To protect yourself against these common power issues you should invest in an Uninterruptible Power Supply or UPS. A UPS is basically a battery backup that will provide power when brown-outs or black-outs occur and will protect the delicate electronics in your PC. You can purchase them at most stores that sell computers and components.
Nov 10, 2009 | E-Machines Emachine T5026 power supply **...
My wife has an eMachines T1600 in her first grade classroom. It worked in June when class ended, but does nothing now when we push the on button. I suspect the Bestec ATX-250-12E power supply, since...
Hello there martinsjak.
Here's your GEEK-steer ...
First, I'll presume you have of course "lamp-tested" the wall power outlet, as well as the power strip outlet you using, and that also the power cord is in good repair.
With that out of the way, kudos are in order, because your suspicion of the Power Supply Unit (PSU) is very well founded. It is THE most common PC component to fail. Although it could also be the case power button/switch itself, it's likeliest to be the PSU. But regardless of which, the easiest way to find out is to test the PSU.
You have three options:
  1. Manually test it using a multimeter ... Yuk! Only a guy with a plastic pocket-protector (and thinks it's impressive) would pick this one.
  2. Install the suspect PSU into a KNOWN GOOD working PC. If the PC powers up, you know the PSU works. If not ... well you get the picture.
  3. Test it using a PSU Tester. This is a surprisingly desirable option. Why? Because PSU testers are not very expensive, and if you're like most everyone else in this modern era, you'll be in need of testing more than just this one over the course of time. Check out this very solid choice for a Coolmax PS-224 ATX Power Supply Tester.
Which of the above three is your call. Easy-peasy, yeah?
Good luck to you, and thanks for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Sep 25, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
I have a emachine T5082
might be a bad power switch have had trouble like this before
Sep 25, 2009 | E-Machines Emachine T5026 power supply **...
Have T5026 emachine with boot problem
Sounds to me that theres a good chance that the windows files are corrupted. It is possable that its could be hardware, but software is free so start there.
If youve got the recovery disks then put them in and restart. Just attemp a repair of your windows. its worth a shot. you may need to go into your boot setting to boot from disks.
if you havnt got them and you havnt got warrenty them youll have to format the drive and install a fresh copy of windows, and find all the drivers from the emachines after.
1st get all the stuff off the drive that you need/want, take the drive out and connect it to another pc or use some sort of external connection.
then find a copy of windows that matches the licence sticker on the case of your pc. throw the hdd back in and boot the disk, format the drive and install windows.
youll have to get the drivers from
Feb 04, 2009 | E-Machines Emachine T5026 power supply **...
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | System Power Supplies
Screen goes blank after booted up
try replacing the memory module on the laptop as the resources on the memory is shared with the graphix
Nov 26, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
System Power Supplies Logo
662 people viewed this question
Top Dell System Power Supplies Experts
Brian Sullivan
Brian Sullivan
Are you a Dell System Power Supply Expert? Answer questions, earn points and help others
