Question about Orion1934 19" TV
Orion tv1934 19" Has Sound but no Picture
My daughter's TV just started this problem. Can you give any assistance? Blessings, Joy
  • lavendersun Sep 08, 2007
    How can I get a schematic? And can you give an estimation on how much this might cost. I know all shops are different, but can you give me a ball park estimate?
    Blessings,
    Joy
    Genius:
  • 1,139 Answers
This could be an indication of the horizontal/High Voltage stage having a problem. You are going to have to take ths to a shop to have it fixed since the HV section can kill you if you do something wrong. There are however some checks you can do if you had a schematic.
Posted on Sep 08, 2007
  • Anonymous Sep 08, 2007
    If we are looking a HV proble this can range from $80.00 - $200.00 depending on the parts used. Taking into mind that the IHVT might be bad. That is why it is important to ask for an estimet prior to any work being done. I have charged up to $250.00 for this type of work in my shop (IHVT, HOT, and voltage reg) were bad in that case the IHVT being the most expensive at $125.00 (This was re-furbished). So that is the most you can expect to spend about 180 on parts and the rest is labor. You can get OEM schematic from the set manufacture, or look online for a service manual outlet (for 20-30 dollars)
SOURCE:
Picture probs with Orion 14"CRT TV
there is a poor or many poor solder joints in the vertical section of you tv, this is a simple repair for a technician. the set should not be used until this is fixed or this could damage other parts of the television.
Oct 07, 2009 | Televison & Video
Dvd's will give sound but no picture on tv.
Double check that your scart connection is fitting fully home in both the rear sockets of the DVD & the TV, this is a common problem if they are not making full contact.
Sep 19, 2009 | Orion Televison & Video
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
We have an orion 2501B TV.no vertical display
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Jun 30, 2009 | Orion Televison & Video
Orion tv combi
check your settings on both the tv and vcr.
Jul 15, 2008 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Orion TV
IT COULD BE DUST INSIDE YOUR TV STEP 1 UNPLUG the tv STEP 2 blow dust from back vents
May 27, 2008 | Orion STV2763 27" TV
Believe speakers are blown in son's TV
Hi there could be more problem then speakers. this tv could have a bad audio ic or capacitor which would cause same problem
But you could use a generic speaker here is a company that sells lots of tv part that consumers could use mcm electronics ,com
thanks DOCTOR VIDEO
Apr 25, 2008 | Orion1934 19" TV
Orion STV2551 27"TV...
The flyback transformer, and some other components may have failed. The main power supply may also be damaged.
It is impossible to know the exact failed parts without trouble shooting the set.
Jerry G.
Apr 14, 2008 | Orion STV2763 27" TV
Picture but no sound
check menu to see if audio is on not off and if you can try external speakers this will eliminate the problem. If exter. works and inter. does not then its the sound board.
Sep 22, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
358 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
