Question about HP OfficeJet 6210 All-In-One InkJet Printer
My Hp 6210 is skipping lines and moving the paper down
I've only had the printer a little over a year and several months ago it started this problem. It starts printing and a little bit down the page it will skip spaces then double print a line, but it looks kinda of smeared, like it was stuck to the printhead or something. By the time it gets done the bottom half of the page is missing all the information. Any suggestions?
  • 24 Answers
Note :--do not use refilled cartridges Step 1: Did you just install a new tri-color or photo cartridge? If all three of the following are true, the problem can probably be solved just by letting the printer sit for 30 minutes: You just installed a photo or tri-color print cartridge (the cartridge can be either new or previously-used) The problem appeared right after you installed the cartridge The recently-installed cartridge is the one that is printing the defective patterns on the diagnostic page Sometimes when a tri-color or photo print cartridge is snapped into the print carriage, it ingests a small amount of air, which can prevent some nozzles from working properly. The air soon works its way out of the cartridge. Step 2: Run the clean print cartridges utility If the step above did not solve the problem, clean the print cartridges. Press the Setup button. Use the arrow keys to select Tools and then press the OK button. Select Clean Print Cartridge and then press OK . The device prints a test page. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning. Open the Printer Toolbox . There are two ways to do this: Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox . If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints. Step 3: Clean the contacts If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage in the printer. Gather the following items to clean the cartridge and print carriage: Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap-water can contain contaminants that damage the cartridge. Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well) Sheets of paper or a paper towel to rest the cartridges on during cleaning Open the printer cover and wait until the print carriage stops moving. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles. Unplug the printer. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp. Clean the print-cartridge contacts. Do not touch the nozzles. Clean the contacts in the print carriage, inside the printer. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it. Reinstall the cartridge, plug the printer back in, and close the printer cover. Try to print again. If the issue still appears, proceed to the next step. Step 4: Black cartridges only: remove and rest for two hours NOTE: The following procedure does not fix missing lines or streaked bars printed by the tri-color, photo, or gray photo cartridges, or other color-printing problems. Perform the following steps only if the black print cartridge has printed defective patterns or if you notice non-uniform black text-darkness. In the black print cartridge, this problem might be caused by sediments collecting in the nozzle area. Perform the following steps to solve this problem: Remove the black print cartridge. If the carriage has a latch, re-latch it and then close the printer. NOTE: If the printer is not closed, it cannot adequately protect the remaining tri-color cartridge. Place the cartridge on a level surface with the nozzles up (label down). Allow the cartridge to sit undisturbed for two hours. Reinstall the cartridge and print another diagnostic page. Load letter or A4 unused plain white paper into the input tray. Press and hold the Cancel button and then press the Start Copy Color button. Make sure that the test patterns show a complete grid and the thick color lines are complete. More than a few broken lines in a pattern can indicate a problem with the nozzles. You might need to clean the print cartridges. If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black print cartridge in the right slot. If any of the color lines are missing, or if the pattern appears faded, streaked, or shows lines, this might indicate a problem with the tri-color print cartridge in the left slot. Look for defects on the page. If the diagnostic page shows no defects for the black cartridge, and if the cartridge was new, align the cartridge. To align the cartridge, follow the steps: Load letter, A4, or legal unused plain white paper into the input tray. In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Toolbox . NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device . The Printer Toolbox appears. Click the Device Services tab. Click Align the Print Cartridges and a print cartridge alignment sheet is printed. Load the print cartridge alignment sheet with the print side down on the right front corner of the glass. Press the Start Scan/Reprints button and the HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet. For aligning the cartridges from the hardware only, follow the steps: Load letter or A4 unused plain white paper into the input tray. Press and hold the Cancel button and then the On/Power button. While the Check Paper and Check Print Cartridge lights are blinking, press the following buttons one at a time in the following order: Cancel , Number of Copies , Paper Type , Color Start If the page still shows defects, go to the next step. Step 5: Replace the problem cartridge If the problem has not been solved by the steps above, either the printer or the problem cartridge is defective. If you have not tried cartridge replacement previously to solve this problem, replace the problem cartridge now. Click here to see if your cartridge is covered under warranty (c00059195). If you have already tried cartridge replacement and it did not help, service the printer. Preventing missing lines Missing lines occur when the cartridge nozzles dry out, or when a cartridge is running low on ink. Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it. After you have removed the protective tape, do not allow anything to touch the nozzles. Print at least once a month to keep the print cartridges in good working order. Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges. If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector. If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up.
Posted on Sep 25, 2007
Turn printer on and all lights flash. On how many copies it shows an E. I had replaced the black cartridge about a month ago. The other three I installed them a day ago. I can get ink from the blue and pink but not from the yellow. Is this defective? I did order these on line
Posted on Oct 29, 2008
Had the same problem with my printer. After reinstalling the HP 364 Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standaardtabel; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} cartridge the problem was gone. The solution aboveis indeed helpfull!
Posted on Sep 01, 2008
SOURCE:
Having troubles printing on a 4 x 6 Index card. I choose that option, but it continues to print on regular size paper. The 4x6 cards are in the 4x6 photo tray. I've tried all the settings I can think...
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Sep 18, 2010 | HP Photosmart C7280 Laser Printer
What kindof printer doyou recomend fora hp2009m slimline desktop
Almost any HP, printer. Depends on how much volume your going to do and the speed you want.
I don't care what anyone anywhere says. No one can touch an HP for reliability. I service those at several Universities and Hospitals and have several of the small HP laser printers with well over a million pages on them. Some in the 2 million page count. You throw in a maintenance kit every now and then and they just flat out run.
I have serviced Lexmark, Xerox, Sharp, Canon,Ricoh and some other off brands. I do NOT sell anything, so to take the sales point of view out of it. I see the productivity and longevity of the HP printers every day I work. They have no close competition. They are in a class of their own.
Mar 31, 2010 | HP DeskJet F380 All-In-One Printer
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
MY CLP-300 PRINTER IS NOT PRINTING BLACK TXT WELL (OTHER COLOURS FINE) DESPITE HAVING A NEW BLACK TONER CARTRIDGE CAN ANYONE EXPLAIN WHY ?
Spend a little time searching the topic on google and even this post. It appears that this has been a well documented problem since at least early 2008. The problem appears to be the imaging unit. According to several posts, Samsung has replaced several of the units. I purchased my CLP-300 in November 2008 and it worked with no problems until about 8 months in. The black text would print very lightly on the left side of the page about 1/4 of the way into the page. There was also a streak that ran down the page vertically that disrupted the text. I could change the font to any color and it would print just fine. After replacing several toner cartridges, I just began to print in a dark color for many months. After discovering all the posts on the internet this week, I contacted Samsung today with my documentation and evidence. They basically blew me off stating that I was outside of the 1 year warranty period and there was nothing they could do. I was even hung up on by a Samsung employee named Michael. Tonight I plan to take a hammer to it to relieve a little frustration. I cannot understand why Samsung chooses to ignore this well documented problem. Good luck.
Jan 07, 2010 | Samsung CLP 300 Laser Printer
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printing problem
You will need to clean cartridges and printer head with cotton swab and rubbing alcohol. Some printers have a self-cleaning diagnostic setting on them.
After thourough cleaning, print test page and use alignment if necessary.
May 15, 2009 | HP LaserJet III Printer
Canon i950 printing many blank strips/areas where text should be
I'm afraid it looks like the printhead is broken. A quick google sees them at about £80. Compare this to the price of a new model. I think 5-6 years insn't too bad though
Mar 23, 2009 | Canon i950 InkJet Photo Printer
Printing
when you have this problem of your printer disconnect it remove ink catridge colector and clean .
Feb 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer acts like it's working then produces a blank page
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Jul 31, 2007 | Dell A920 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
1,365 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
