Question about Gateway 500GR PC Desktop
No power i came home frome work the other day,push the power button on my computer there was no power ,i looked inside there was one green lite on on the mother board. i do not understane why it want come on please help
  • poky Sep 08, 2007
    ibought a new power supply but when i put it in it does the same thing oh one thing,when i pluged it up,i got a electric pop from the cord,but i still get that little green lite on the motherboard.
    Sergeant:
  • 279 Answers
There are quite a few possibilities here. Do you leave your computer on while you're not home? If so, it's possible the computer overheated. If that happened, most likely you processor is damaged, and will have to be replaced. There may have been a power surge, which could have damaged the power suppply or the motherboard. It does nothing when you push the button? There's also a remote chance the switch is merely broken... though I can't say I've ever actually seen that happen. If it does absolutely nothing, it's most likely the power supply, however. If the motherboard or processor were bad, it would probably beep when you tried to turn it on. Not definitely, but probably.
Posted on Sep 07, 2007
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
TV doen't turn on
Its time to buy a new one, buddy.
Oct 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Power light and opc lights blinking green
It can be the power supply is sensing short circuits in the power supply itself or in the backlight inverter board, those are the two areas you need to inspect.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 10, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I turn the DS lite power button on and the green
well go online type get ds fixed the they will tke it for 2 days
Oct 12, 2009 | Nintendo DS Lite Console
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
Gateway 500GR PC Desktop Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
