Whirlpool washer pump inlet filter
I have a Whirlpool Ultimate Care II topload washer. Is there a pump filter before the pump inlet? If so where? thanks for your help.
  • Anonymous Mar 25, 2014
    How to locate drain pump filter for a whirlpool
  • 641 Answers
No, there is no filter before the pump inlet.
Posted on Sep 07, 2007
SOURCE:
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
Hi.
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Ultimate II topload fills with water but does nothing else. The lid switch appears OK
it might look ok but not all the time it is. If the switch is good, maybe it is a burnt or bad connection at the motor. or it could be a bad motor
Mar 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate Care II toploading washer doesn't empty or spin after ag
Hello, I can help.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Jun 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer leaks out bottom
three places,,all in one area..the pump,,,the drain hose to the pump (in unit),,or the tub topump hose...one of them is defective..onthejob...if you need instructions on how to get in unit reply ..
Jan 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
