Misfeed Error, or Timing Error. You need dealer service. This is a Professional Machine. The fuser only heats the toner to set it on the paper. It is nothing to do with jams.
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
I have had in the past on these models that when paper is being fed to the exit section the exit rollers are not spinning so paper doesnt get pushed through to the output tray. If this is the case then you will need to replace the exit roller drive motor and possible the PRCB too as sometimes when the motor becomes faulty it knocks out the PRCB ICP chip on the board.
The unit that provides high current to the magnetic field of the fuser is bad, located below the control panel and behind a cover, recommend tech look at it can be very expensive.
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
please give correct info... there is no bizhub c362 there is a c352 but your post is in the c203.... if its a c203 then the tx reports are in the utility/counter then common settings. i can help you more if needed
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
