Question about Kenmore 54501 Dehumidifier
How to connect drain hose?
I know I am going to kick myself when I get the answer...... I can't figure out how to connect the drain hose to the dehumidifier. I lost the manual. Thanks!
  • 2 more comments
  • PALrose Nov 26, 2007
    I have paid someone to connect my Kenmore 54501 dehumidifier so it empties into a hose that goes outside, instead of emptying the pail every 2 days as the machine is in my attice and hard to get to. He has been back now 3 times as the pail is still filling up. We don't know what to do. He has taped the piece on etc. Could there be a piece (a clamp) missing? I don't have a manual and would like one but also I'd like to see one online to see what we are doing wrong. He thinks a piece is missing.
    I have paid someone who has been here 3 times to hook my dehumidifier to drain to the outside via a hose. For some reason the pail keeps filling up instead. I do not have a manual but called for info. We don't know what is wrong. Could a piece like a "clamp" be missing? Please help.
    He has already taped the connector piece to the dehumidifier on the outside and just now puttied it inside. I think it's puttied between the connector and the black rubbery piece. He said some water was in the hose but the pail was also full. It's in my attic and I am disabled so I can't empty the pail every 2 days.
  • stupidmachin Nov 16, 2008
    I have the same problem. I have reconnected it several times, but the bucket keeps filling up instead of draining through the hose.
    Please help!
  • drpankajgarg May 11, 2010
    i did that but water is still collecting in bucket
You need the white pipe that came with it. Remove the circle on the back left of the unit with pliers or a screwdriver. Take out the bucket. screw the hose to the pipe. Push the pipe through the hole in back and break through the rubber membrane. In front, connect the white pipe to the elbow pipe at the top. Make sure the smaller tab on the white pipe (back of machine) is pointing down and the larger one up. The smaller tab goes behind the back cover and (sort of) holds the pipe in place. You still need the bucket in place for the machine to turn on.
Posted on Sep 25, 2007
  • RayinBoston Jul 05, 2011
    Does it matter if the hose is coiled on the ground? Also, I removed that "rubber membrane" around the hole that the white pipe comes in through? Is that o.k.?
    By the way, that elbow pipe that the white pipe connects to, doesn't seem to have any opening to it. How does the water from the bucket get into it, and ultimately out the hose?
I have an Energy Star 54701. Turned on, 35 % humidity set, hose connected and ready to drain in sump hole, bucket connected. set for 6 hours. No water is draining from hose or into bucket????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Soleus 30-Pint Dehumidifier
I love this dehumidifier, but can not figure out how to connect a hose to the bucket so that it continually drains, as opposed to the bucket filling up. Where is the connection for the hose on this unit?
Terry, the hose connection should be on the rear of the uni, covered by a screw off cap. The hose can be not longer than 48" and should slope down and straight to the floor drain. As, proper drainage relies entirely on gravity.
Hope this helped you and thanks for choosing FixYa.
Aug 25, 2011 | LG Goldstar 30-Pint Dehumidifier
I connected a hose to my dehumidifier to drain the water. The water is still going in the dehumidifiers tank. What else do I need to do?
Check the hose connection on the dehumidifier, as well as the hose for clogs. That is what usually happens when a hose is connected and it doesn't drain properly.
Also, the hose should be no more than 5 feet long and MUST slope downward to drain properly. As, the drain relies entirely on gravity. There is no pump.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 06, 2011 | Maytag M7DH45B2A Dehumidifier
Need manual with exploded diagram
If your model has a condensate (water) reservoir, there should either be a threaded hose fitting located at the bottom of the reservoir that will accept a standard garden hose, once you punch out the plug inside the threaded coupler.
If you do not have a threaded hose coupler on your unit's reservoir, remove the reservoir and look inside the area above it and there should be a small hose fitting that you can attach a standard garden hose to, to allow for constant draining without having to use and empty the condensate reservoir daily, etc.
If you don't have either of these items, you'll need to purchase a new condensate reservoir with a hose drain attachment to allow use of an auxillary drain hose. You'll need to contact Maytag customer service for the correct parts and assistance.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(866)616-2601 U.S.
(800)688-2002 Canada
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | Maytag M7DH45B2A Dehumidifier
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
Fdk45p1 dehumidifier
Has anyone figured out how to get a 25-pint Frigidaire dehumidifier (model FDD25S1) to put water out the drain hose for continuous draining instead of into the bucket? It appears to be impossible to connect the hose in a way to avoid water leaking into the bucket.
Jun 06, 2008 | Frigidaire FDL45P1 Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Lost suction to drain into hose connector
I've had a similar problem and I was told by Whirlpool that the hose has to run down along the side of the dehumidifier and not straight out. I moved it and things improved; then I moved it again and it got worse. So maybe you moved the hose while cleaning the vent, and moving the position around will help?
Aug 28, 2007 | LG DH30 GoldStar Dehumidifier
Kenmore 54501 Dehumidifier Logo
1,532 people viewed this question
Top Kenmore Dehumidifiers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
