Question about HP (D7580-60003) Motherboard
Hp motherboard I just installed a motherboard and the button that you cut on the computor with that cord that goes to the motherboard don't line up with the pronges on the motherboard is their adapter that I can get
    Novelist:
  • 231 Answers
Hi, I assume you are refering to the plug wires from the case to the motherboard. There is no adaptor because most motherboards have a slightly diferent layout The speaker wire and plug is usualy on a spread plug, sometimes the led and switch plugs can be also on a spread plug patern, If this is your problem then get a very small set of side cutters, toenail cutters will do, and very carefully cut the plug to seperate the two individual plugs, then just plug the wires onto the pins, Turn them side ways so they do not interfere with each other. Goodluck mistyman
Posted on Sep 08, 2007
SOURCE:
Utilitech #73189 installation
Utilitec 73189 is ordinary 120Volt fluorescent light.
Where are you installing this light?
Are you wanting to hardwire this light so it connects directly to a switch?
Does the light have a plug-in cord?
Or do you want instructions how to wire a plug-in cord to the light? And then install small rotary line switch on the cord.
I would buy a cheap extension cord that already has ends. And buy rotary line switch that fits the cord.
Then cut off one end of extension cord so it will plug into outlet.
Install the line switch onto the cord.
Connect the cut-end of extension cord to light fixture, black-to-black white-to-white-green-to-green.
Add a comment and include more detail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 20, 2012 | Hardware & Accessories
Computor won't power up. in power saving mode
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 06, 2012 | Gateway Computers & Internet
Don't know how to fit the wire into the inside of the switch
Since there are only 2 wires, it doesn't matter which wire goes where. Either way it will work.
Apr 26, 2010 | Pass & Seymour #5410WBPCC5 White In Line...
I can''t get the photos to down load
make sure the software on the included cd is installed
Nov 14, 2009 | Sakar Digital Concepts Digital Camera and...
Computor will not come on. green light in back is
This sounds like either your motherboard or power supply is shot, if it is still under warranty you can get HP to send you a new power supply or send your PC back to them and they should fix it for you.
You can check your warranty status online on HP's website here.
Hope this helps.
Nov 13, 2009 | HP Media Center m1180n PC Desktop
The last line of every document is cut off and the bottom half is missing as though the margin isn't long enough, but that's not the case.
Try to print a self test page using the below steps
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.If this prints fine, perform the partial reset of the printer using the below steps:
    1. Unplug the power cord from the HP All-in-One.
    2. Wait for 20 seconds.
    3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
    4. Release the buttons after the HP All-in-One starts up.
    5. The HP All-in-One will now be reset to factory defaults.
Sep 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Monitor wont stay on when you start computor,its goes green for 5 seconds then straight back to standby,monitor works fine on my other computor.
Its totally ur internal CPU problem.
checkout ur motherboard, microprocessor & fan also from wellknown person.
Dont do anything at home.
Aug 06, 2009 | MSI K8MM-V Motherboard
CONNECTING MY HP6110 PRIBTER TO MY HOME LINE, WHAT DO I HAVE TO D
Most HP OfficeJet printers have a generic driver already installed in Windows XP and Vista computers.
All you have to do is to connect the printer without installing any driver or CD and let the computer detect the printer. The compute will ask you if you would like to install the generic driver.
If you really would like to use the post script driver, kindly check this link and click the download button:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/HP/Hp-officejet-6105-6110-all-in-one-210.shtml
Apr 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
YANG AN YA-1 E114139 94V-0
I want drivers for the motherboard: YANG AN YA-1 E114139 94V-0
Mar 28, 2008 | HP (D7580-60003) Motherboard
HP (D7580-60003) Motherboard Logo
55 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
