Question about Libec ST30 Tripod
Libec THM20 One of the extendable legs is sticking. It isn't bent and I can't see any blockages. Could it be the locking mechanism?
  • 1 more comment
  • Anonymous Dec 06, 2007
    The leg is slightly off the track, which is a curved piece which fits along the tripod support rail. If you're not careful when collapsing the legs you'll force the leg to go off-track like this.
  • Orange 23 Dec 06, 2007
    Unfortunately it is not off the track. There's something sticking within the actuall locking mechanism. Thanks for replying though.
  • Anonymous Mar 18, 2014
    THE LOCKING MECHANISM DOES NOT KEEP THE LEGS IN PLACE
Posted on Dec 06, 2007
How can I replace the quick release head for the libec th659dv tripod. A student has lost the plate but UK retailers do not seem to stock libec replacements.
Try a plate from another tripod. I have three different tripods, and the quick-release plates are all interchangeable.
Jul 08, 2015 | Libec Photography
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
Clk 2005 - I'm having problems closing the glovebox... Doesn't close unless I give it real slammmmm..!! Can anyone help
Lube the locking mechanism to make sure that it isn't sticking in the locked position. If it doesn't fix the problem, then make sure that the linkage inside isn't broken or bent. If neither work then the latch will need to be replaced.
Oct 10, 2012 | Cars & Trucks
How do I perform a ball push-up exercise?
You should lie prone with your thighs on top of the exercise ball, legs and back fully extended and hands on the floor, elbows bent. Then you'll need to push yourself up by extending your arms and slowly lower yourself back down after a short pause.
Aug 02, 2012 | Exercise & Fitness
Vivitar 980 leg lock replacement
Who are these people designing the leg locks. These are the poorest examples of engineering. Even a child could see that the leg lock begs to be broken. Maybe Vivitar should stick to flashes
Apr 22, 2012 | Vivitar Photography
Biscuit the dog has a bent leg
You're probably going to need to remove the fur and examine the leg to see if there is a bent rod or connection joint that you can bend back out. Contact Hasbro's Customer Service for the instructions on how to remove the fur if you're not sure. They may have resources for you such as repair shops locally or in-house repair you might be able to send it for repair. if it is out of warranty, and you did not buy an extended warranty, they may charge for the service. Good luck :)
Dec 20, 2011 | Hasbro FurReal Friends My Lovin Pup...
Locking tripod leg
Sorry, the mechanism and how it is put together should be repaired my Manfrotto. It has a one yar warranty when you bought it, and if you went to the Manfrotto website and registered it then the warranty is 3 years.
Jun 09, 2010 | Manfrotto 458B Neotec Pro Photo Tripod...
High hat for Libec T98C
Try the site www.transfilm.com they are a repair facility and reseller of used equipment and might have what you are looking for.
Aug 03, 2008 | Libec Photography
Libec T58 Tripod
I had a Porter-Cable that I was able to repair using three small pieces of lexan and a bandsaw. I took off one of the latches that were good and traced the pattern on the lexan and sawed out the handles. Cleaned them up with sandpaper andthen stacked them and drilled out the holes. Then I drilled two more holes for clearance for two 6-32 machine screws and nuts. Put the whole thing together and installed it - still working after four years.
Aug 21, 2007 | Libec LS-55 Aluminum Tripod System -...
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Libec ST30 Tripod Logo
131 people viewed this question
Top Libec Photography Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Libec Photography Expert? Answer questions, earn points and help others
