Question about JBL CREATURE II Computer Speakers
Volume control buttons on Creature II speakers
The volume control buttons on the satellite speaker do not work. I can adjust the volume using the controls on my MacBook and Ipod. But nothing happens when I use the touch buttons on the speaker itself. Otherwise, the system works fine.
  • 4 more comments
  • Anonymous Jan 18, 2008
    same problem with the volume control buttons.  They do not work.  New system used a few times and that is it.
  • Pepo Calde Jan 28, 2008
    hey im not an expert but i tried to fix the same problem that u have, first i put some penetrant and some contact cleaner on both buttons and nothing, then i started to move my thumb palm (idk how to call it, bethoween the 2nd and 3rd joint starting from the nail of the thumb) upon the button and moved it up and down and every 3 moves the volume raised a little bit so u need to be patience it worked for me
  • ptjordan7 Jan 06, 2009
    yes, i have the same problem although when i tried the thumb method, it did not work. if anyone finds another solution, type it up. i would be very interested
  • Anonymous Mar 09, 2009
    Exactly the same. Touch controls do not work at all. Should I take the whole system to the technic support?
  • franje Apr 12, 2009
    Thank you Dekalo, I couldn't adjust the sound, so I did what you said (I didn't use any solvent) but I kept working the volume with my thumb, nail and knuckle and I unplugged and replugged the sound speaker and it finally took and I have beautiful sound.
  • Anonymous Mar 15, 2014
    The right speaker, which controls the volume, had a broken pin in the connector, thus not working at all. I got the little connector changed by a friend and got both speakers to work but the sound becomes gritty/rattling (on the right speaker) when I turn the volume a little high. And If I crank it up it starts to cut off in both speakers. I have to touch the volume again to have sound coming out and I don't know if it is the cable with the new connector, the speaker buttons or the speakers being blown up. Does any one have an idea of what it could be and how to fix?
    President:
  • 2,022 Answers
This problem is bcoz of the buttons only it require servicing see if you can show to service pesonnel he will help you out.
Posted on Sep 24, 2007
Funny but that worked. I unplugged everything then re plugged. but I used the part of my finger behind the knuckle and it worked.Thank you Dekalo.
Posted on Apr 30, 2008
Try to simply disconnect and reconnect the right channel cable to the subwoofer.
Posted on Apr 11, 2008
How to increase speaker volume on my laptop
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hop this helps
Jun 09, 2012 | JBL CREATURE II Computer Speakers
The speakers are in silence, ????
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 02, 2010 | JBL CREATURE II Computer Speakers
Hey there, I have JLB Creature II speakers, that have been working fine for nearly a year. Until one day, when the treble's maximum volume became a lot lower than before. The bass still rocks it up like...
Hi Nikita,
The problem may be with the internal electronics of these speakers, especially the sub-system that controls the treble. If they are still under warranty, you should talk to the dealer. If not, you should contact a technician.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | JBL CREATURE II Computer Speakers
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
Jan 10, 2010 | JBL CREATURE II Computer Speakers
Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
Jun 14, 2009 | JBL CREATURE II Computer Speakers
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
May 30, 2009 | JBL CREATURE II Computer Speakers
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
JBL CREATURE II Computer Speakers Logo
2,525 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
