Question about Epson Aculaser C1100 Printer
Aculaser C1900 My problem is I have a gap in the printed page about 2cm wide with no print in this area, can u help. regards pauge
  • Epson Master
  • 705 Answers
Sounds like you have a spot of toner on the laser lens. Pull out the waste toner bottle and toward the left of center you will see a little handle sticking out. This is the cleaner pads that wipes the lens. Pull it in and out a few times. Put the waste bottle back in and print a page or two. you should find your good as new again.
Posted on Sep 17, 2007
SOURCE:
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Cyan toner problem
Is the section that is not printing down the r/h side of the page?
If so then it is likely that one of your toners is not "locked" in fully. Open the top panel, lift up the orange lever and pull out the PCU. You can now rotate the cartridges, check each one is fully locked in by the coloured levers on the r/h side. Even if one is slightly raised it will block the path of the laser and cause the symptoms that you describe.
Mar 07, 2009 | Epson Aculaser C1100 Printer
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Service Req C0302
CPU Error. Mainboard is faulty.
Jul 04, 2008 | Epson AcuLaser C1900 Printer
Acculaser C1900 Printing too low on paper
Which post. There are hundreds of thousands to choose from.
Jun 27, 2008 | Epson AcuLaser C1900 Printer
Prints black perfectly/colour print blank
the photoconductor unit may need replacing ? have you given your printer a service ? clean out all the dust from your unit making sure you dont touch the conductor unit do the best you can and try it again ok making sure the wast collector is empty too thanks
Apr 16, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 paper jams and almost no ink
If paper jam occurs frequently, wipe the pickup roller with a clean dampened cloth. Follow the steps below:
  1. Open Cover AB of the printer.
  2. Open the cover below the paper path roller.
  3. With a clean dampened cloth, wipe the pickup roller.
  4. Close Cover AB.
If the glass on the print head filter is dirty with toner, wipe it with a clean cloth. A vertical white line may appear in the printout. Follow the steps below:
  1. Open the front cover.
  2. Tilt the waste toner collector and pull it out.
  3. Grasp the handle of the print head filter with your fingers and gently pull it straight out of the slot. (**Note: Be careful not to spill toner that has accumulated on the print head filter. )
  4. With a clean cloth, wipe the glass surface of print head filter.
  5. Hold the print head filter by the handle and gently insert it all the way into the slot.
  6. Reinstall the waste toner collector.
  7. Close the front cover.
The print quality problem might be something as simple as turning off the Toner Save mode using the printer driver or the printer's control panel menus.
There may be a problem with the photoconductor unit. You may need to replace the photoconducter unit.
Or it might be something rather more serious (hopefully, not)Print out a status sheet. If a blank page is ejected, the problem may be with the printer. Turn off the printer and contact your dealer.
Jan 04, 2008 | Epson AcuLaser C1900 Printer
Epson Aculaser C1100 Printer Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
