Question about Epson Stylus R265 InkJet Photo Printer
Lost reverse side printing option
For two years or more I have produced a low volume (approx 50) monthly newsletter using Publisher. Usually this consists of 4 sides but I have always used the "manual duplex print" & "two pages per sheet" options to produce a centre folded, double-sided A5 booklet in full colour. Until recently I have used HP printers without too many problems, but recently I purchased an Epson R265 and found that the printing order options couldn't cope with this basic requirement. I overcame that by simply removing the page numbers in Publisher and re-ordering the pages so that Page 4 become page 2 and vice versa. Now, however I have lost the reverse side option. It's just disappeared from the properties!Am I going crazy? Phil
  • Achilles2k Mar 23, 2008
    I have lost the option to print double-sided. It was there until recently - now it is greyed out an cannot be selected.
    Any ideas??
    cheers.
    Novelist:
  • 110 Answers
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Posted on Aug 22, 2008
I had microsoft publisher 98 installed on my computer but the system crashed so I need to reinstall. Problem is that I purchased the software years ago and still use it to make newsletters, cards, etc....
It is not possible to install it without the auth code. You can contact microsfot and they can provide you with an auth code you can proceeed with.
Apr 05, 2013 | Microsoft Publisher
Kyocera KM 5050 printing problem
nope tech guy is corect way these are set up ok thx for using fix ya
Feb 06, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
How do I make an 11x17 newsletter on my canon 3530
If you are trying to print this from your computer to the IMAGERUNNER 3530 Copier, you need to access the "page setup" portion of the program you are using to produce the original artwork. If you are using "Publisher" or "Photoshop", for example, go to "File", Page Setup and change the paper size to 11" X 17". You will also need to tell it which tray in the IMAGERUNNER 3530 Copier you have put paper into.
If you are up-sizing the page from a previous size (ie: 8.5" X 11 or 8.5" X 14") you need to use the enlarge feature to scan into the IMAGERUNNER 3530 Copier and output to 11" X 17".
Let me know if I can be of any additional assistance.
May 27, 2011 | Canon IMAGERUNNER 3530 Copier
What are the application/uses of ms publisher 2007
Microsoft Publisher 2007 is a desktop publishing program that helps to create newsletters, brochures, business cards, flyers and other publications.
Read more: How to Use MS Publisher 2007 ' eHow.com http://www.ehow.com/how_6218902_use-ms-publisher-2007.html#ixzz1M68DDQhe
May 12, 2011 | Computers & Internet
What is MS Publisher 2007? How to create FLYERS using MS Publisher? How to create BROCHURES using MS Publisher? How to create NEWSLETTER using MS Publisher?
Publisher is a program that makes it easier to make "posters" and "brochures" and "newsletters".
Start the program. Click "New". Click "start a new FLYER", or "start a new BROCHURE", or "start a new NEWSLETTER", to use some of the pre-defined templates that define the layout of your publication (fan-fold, multi-column, et cetera).
Feb 03, 2011 | Microsoft Office Professional 2007 Full...
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
How do I print only page 4 of a newsletter?
Rather than just click on the print icon click on file then select print. You should then be able to select the pages you want to print.
Jan 09, 2011 | Belltech Systems Small Business Publisher
I'm using MS Publisher 2007 and pdf creation problem
  1. On the File menu, click Publish as PDF or XPS.
  2. In the File name list, type or select a name for the publication.
  3. In the Save as type list, click PDF.
  4. Next to Optimize for, click Change.
  5. In the Publish Options dialog box, click the optimization in the Specify how this publication will be printed or distributed list that matches the needs of the publication. For example, if the publication will be distributed online and print quality is less important than a small file size, click Minimum size. If the quality of the printing is more important than file size, click High quality printing.
  6. Click Advanced to display the entire dialog box, and select the settings that you need. (Find links to more information on these options in the See Also section.)
  7. Click OK.
  8. In the Save As dialog box, if you want to open the file immediately after saving it, select the Open file after publishing check box. This check box is available only if you have a PDF reader installed on your computer, and if the Commercial Press option is not selected in the Publish Options dialog box.
  9. Click Save.
Feb 10, 2009 | Microsoft Office Publisher 2007 for PC
MS Publisher 2003
i can not open microsoft publisher document
Apr 17, 2008 | Microsoft Office Publisher 2003 for PC
Epson Stylus R265 InkJet Photo Printer Logo
261 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
