Sony kv32ls35u 32" widescreen TV fault
My TV is approximately 4.5 years old, whilst watching the TV, it made a pop sound then went into standby, the LED on the front flashes red 11 times, then waits a few seconds before repeating the cycle. I've taken the TV apart now in the hope of finding the defective component. Sony have told me that it would be uneconomical to repair it. Any help or advice would be greatly appreciated.
  • 5 more comments
  • shajju Nov 04, 2007
    Hi
    I have the same problem. Don't want to throw the set away.
    Regards
    Sheraz
  • Anonymous May 01, 2008
    On our tv the standby light flashes 11 times and does not work at all?
  • course1 May 01, 2008
    Our tv standby light flashes 11 times when switched on, tv is not working at all.
  • xagtrules Aug 27, 2008
    yep i have the same problem tv wont turn on anymore .i go to turn it on the green light flashes then turns red when its supposed to go on and turns off. and flashes 10 times . although if when its initially going through green and i hit reset sometimes it turned on so i left it on for 2 weeks because i was sick of hitting reset 20 -30 times everynight just hoping it will come on. the times it did come on the red button flashed 5 times even though it was on. i wrang sony and they put me on to the repair shop on south road at mile end i think, they said aprox $350 to repair. good $5000 tv we purchased. thought sony was more reliable than this oh well never again. KVHR 32 86 centremetre
    hi all try ringing adelaid telefix in hilton if u r in adelide 8150 9999
  • funkygirl_76 Nov 30, 2008
    Have the EXACT same problem. Exact same Tv, Song Wega CRT Tv had it for abou the same time, 4.5 years. No picture, turns on, turns off.
  • chch120 Dec 05, 2008
    Posted by xagtrules on Aug 27, 2008
    XAGTRules, I have exactly the same problem with the 10 flashes after going through green. Did you get it repaired? how much did it cost?
Hi guys
i am having the problem that when i switched off my tv then in the center of the screen colours comes for few seconds and then vanished though it is not a major problem but i want to see my tv perfect thats why if you guys have some suggestion then plz do let me know on my email adress: creationforever2000@yahoo.com
thanks
Posted on May 01, 2008
My sony trinitron 32 inch widescreen only gives slight flash when you turn it on but sound is working. no picture just sound. picture worked once since this started happening and then went off again. Any...
there might be a problem with the connection of the screen to the motherboard or the wire that connects it might be the fault. but there could be a burnt fuse or components.I would suggest letting a tv tech have a look good day sr
Nov 23, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My Sony Bravia KDL 32S2030 is showing a flashing led standby (4 flashes/2 secs/4 flashes. I can unplug the mains cable, leave it for a few minutes and when I pug it back in it will re-set to the green...
I'm not a service tech, but, I do have a copy of the service manual. It says the TV has a self diagnostics and according to the chart, 4 flashes indicates a backlight failure.
Oct 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
Tv shut itself off while I was watching.
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toshiba HD made a popping sound and went out.
Check the lamp to see if it popped. Try replacing it. Also check the web for class action law suit for these sets, Toshiba has an extended warranty for lamps for certain units.
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Black screen on tv but still have sound!
i used to work on the warantee's for relysis from memory that was a deffo dead un we used to swap out on that fault im pretty certain its a dead processing board . . . sadly relysis uk went bust . . . .
Jan 17, 2009 | RCA F32450 32" TV
Sony 27 inch tv
this could be indicator of a bad bulb
May 20, 2008 | Televison & Video
Sony KV 25 F3U
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Sep 16, 2006 | Sony KV-32S26 32" TV
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
Televison & Video Logo
616 people viewed this question
Top Televison & Video Experts
