Question about Brother IntelliFax-2820 Laser Fax
Problems sending and receiving faxes
Message reads: back door open, close back door. Nothing in the rear of the machine is open. Do not understand this message.
  • Anonymous Dec 23, 2008
    error tambor
  • Anonymous Apr 09, 2009
    same problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Then there is a sensor problem, here is the manual check troubleshooting section
http://www.retrevo.com/s/brother+2820+fax++manual
Posted on Dec 26, 2007
6ya staff
SOURCE:
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
Says there is a paper jam but there is not
First, you have to clear the error first before sending the fax.
-open the rear access door at the back and check if there is any debris of paper. If none, close the access door and make sure you hear the snap and properly closed.
-lift the document feeder cover to check for any debris, and then close it properly.
-if error is cleared, try faxing again
Feb 26, 2009 | HP 1040 Plain Paper Inkjet Fax
Brother Fax 2820 gives message: Back Door Open
It could be that a tab is broken off of the door that trips a switch. Cheat the switch with a small folded piece of paper.
Dec 17, 2008 | Brother IntelliFax-2820 Laser Fax
Paper Jam
did you open the rear door and check in the fuser?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
283 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
