Question about Philips Magnavox 20MT4405 20" TV
Maganavox model#19PRC1 0121
THe tv is stuck on what seems to be an in store advertisement. It starts with Here's why this should be your next tv... and then goes into explaining the closed caption, etc. It continually repeats. Can you please tell me how to get this off? THanks!
  • mrglynn81 Jul 09, 2008
    tv is stuck in closed caption mode and we don't have the remote. It doesn't seem to be accessable from the menu.
  • Anonymous Apr 29, 2009
    El problema era no poder controlar mi tv, ya que paresia estar programada en forma de muestra para venta con todo corriento automatico y sin control, pero una vez que presione los botones de volumen y canal para abajo, se arreglo el problema.
    Muchas gracias y suerte
  • 29 Answers
Push the volume down and channel down buttons(on the tv)at the same time.
Posted on Sep 08, 2007
I had to push all 4, tv up-down and vol up-down all at the same time, that is the only thing that worked for me.
Posted on Nov 19, 2009
  • Anonymous Nov 19, 2009
    Thank to all
The person before me had almost the right solution. I had the same problem and tried this, but it didn't work. I pushed volume up and channel up at the same time on the tv, and that worked.
Posted on Jan 10, 2008
SOURCE:
There is a number of pop ups onthe tv stations on the side and the top
It seems like your Tv is on demo mode go to the menu screen select option and search for tv mode turn it from store/demo mode to house mode also check that if demo in on to turn it off
hope i was helpfull
Jul 31, 2014 | LG Televison & Video
Older magnavox - TR2510C101. The TV store advertisment is all it will display. Says "This should be your next TV, etc." Will not shut off or respond. We have to unplug it.
The tv is in the demo mode. To get it out of the demo mode, try this:
Press and hold the VOLUME UP and VOLUME DOWN front panel buttons at the same time. This will take the TV out of that demo mode.
Hope this helps
Jan 28, 2011 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Pre-set message in a continuous loop on tv. Can not get it to stop. Maganavox Model No.: 25TRC10101
Try holding the channel up and volume down buttons together on the front of the set until the set turns off. When you turn it back on it should be normal. If channel up and volume down doesn't work try channel down and volume up. One of the two should do it. This demo mode was for in store demonstration. Thanks
Nov 01, 2009 | Televison & Video
My Maganavox #19PSC5 0121 19''
I just found a solution elsewhere on this site...
In order to make the Demo Mode stop, you should press Volume Up and Channel Up together, and hold for four seconds. This worked for my mom's tv, I hope it works for you, mooone (and everyone else, too).
Jun 01, 2008 | Philips Magnavox 20MS3442 20" TV
I have a Phillips maganavox Projection TV I believe it is model 9P6040CI and the color is dull and I believe the red is going or gone. I've tried to tune it but will not let me
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 02, 2008 | Philips 9P6040C 60" Rear Projection...
Maganavox TV Troubles
Im just gonna guess your TV is a Mag 230 or 230 Your problem is goning to be a defective Y-main and upper and lower Y-buffers.
Get back in touch and ill find the part numbers for ya.
Apr 14, 2008 | Televison & Video
Motorola universal remote DRC800
try one of following codes :0054   -0030  -0179- 0706
Sep 12, 2007 | Motorola Mobility DRC800 Universal Remote...
Philips Magnavox 20MT4405 20" TV Logo
298 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
