Screen is off centered
Every tv has a secret service menu accessed through a secret sequence of buttons on your non-secret remote.
With the power off, press this button sequence:
mute
power on
You should now be seeing the secret service menu.
TOUCH NOTHING IF YOU DON'T KNOW WHAT IT DOES!!!!!!!!!
Before you touch ANYTHING write down what the initial setting was. I mean it mister.
I think hitting volume down selects an option, while hitting "menu" takes you out of that option and into the area you were just in. There are lots of things to do here.
Before you do anything, go to the video options (there ought to be four of them), under one of them (second one I think) is the option to turn VM or SVM on or off (a setting of "zero" is off). For God's sake turn this off. I think it says "VM level" or something. Anything that says "VM" needs to be set to zero.
Now, to center the picture, I think you'll want the very top menu at the start of the service menu. One is horizontal something and the other is vertical something. BTW, it helps to have a test pattern for overscan when doing this. Do you own a copy of Digital Video Essentials? You should. Again, write down settings before you change them, so if you screw up you can fix it. To save your settings, keep hitting menu until you're back to the first screen, and hit mute twice. Then turn your tv off and back on. After using the service menu, my tv is always put in "dynamic" picture mode. Never, ever, ever use this mode. It will make the picture way too bright and kill your tv before its time. Use DVE or another calibration DVD to get the settings right on your tv.
BTW, you can also correct overscan in the service menu, but I wouldn't push it lower than 5%.
