Sony crt 25'' colour problem
Hi i have the above tv and sometimes it loses it's colour for some period of time i think the red is missing what can i do for it thanks in advance for your answers
  • hightmare Sep 18, 2007
    how can i fix this?
    Novelist:
    Champion:
  • 236 Answers
You may have a loose solder connection in the color circuits since your problem is not there all the time. Stargazer
Posted on Sep 18, 2007
  • Simpson Neal Sep 20, 2007
    If you're experience in circuit board repair you can take your set apart and tap around the board with an insulated probe such as a ball plastic ball point pen while observing the picture in a mirror. When you get near the loose connection,you will see the the color change or flash on and off. Also you might try tapping the neck of the picture tube. Don't tap too hard! If you tap the picture tube and the color changes then the problem is in the picture tube.(Hopefully not!)
    The circuit board that plugs onto the neck of the picture tube can develop a loose solder joint that will cause one or more colors to go off. Tap or scrape on the board while watching the picture to see if anything happens.
    If you're not experienced at this type of work it would be best for you to take it to a service technician.
    Stargazer
Sony kv-EF29M80 blue colour missing and takes time to turn on unlike how it was before. the images are blur.what could be the problem and what solution is there for it?
Check the collector voltage of blue output transistor at its video output board, which can be located directly plugged onto the neck of the picture tube. Check for any loose solder terminals at this board.
Dec 04, 2012 | Sony KV-32FX60 TV
Toshiba TV Model 32JW9UA. The Red component of the 3 primary colours has just started to disappear for extended periods, intermittently. If I set the Colour slider and the Tint slider on the TV menu to...
have you tried to manually adjust the convergance?. go into your set up menu there you will find the convergance adjust ment. please rate this..thanks
Sep 25, 2008 | Televison & Video
The colour of our sony tinitron color tv model no.kv-xf21m83 has got fading (Red colour disappeared )and the indicator flashes red a number of times between 3 second intervals and the est is sparking
hi
this sounds as if the tube (crt) as a intermittant short in the red gun , try tapping the neck of the tube very softly with a screw driver handle, this just might just clear the fault
regards windyhouse
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our toshiba 61 inch rear projection tv is losing its colour, all the people are blue.
red crt is dying they are NOT avail anymore time to think about retiring thet set
Nov 28, 2009 | Toshiba 42H81 42" Rear Projection...
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Colours missing from tv
There are three color guns in a TV that make up the picture. Red, Green & Blue. It sounds like you have lost the green color gun.
You can get it rpeaired again, but your TV sounds like it is ready for TV heaven.
Jul 25, 2009 | RCA 20F512T 20" TV
Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
Feb 23, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Zeneth 25"
the filter capacitor of 180 volts is weak or change value ,you need to change it .,the of that is 4.7/250volts or 10/250 volts.
Oct 12, 2008 | Zenith B25A11Z 25" TV
Colour bleed
If it is in one of the corners it is a magnetic interferece problem. Most '90s and later sony tvs have a built in degaussing. Turn the tv off and turn in back on and it will degauss. If you have speakers too close move them away. If you have the tv on and move the speaker away you can see the effect.
Dec 28, 2007 | Sony KV-T29CF1 TV
Pic Bleeding
this sympton is characterized by the presence of red, cyan, green, magenta, blue or yellow colour in a supposedly plain white raster. proper colour reproduction cannot be expected if the raster is coloured. this symptom is caused by a poor white balance adjustment of by a trouble in the CRT, colour amplifier, color demodulation or colour output circuits. if the raster has a tint of red or cyan, check the R-Y output circuits and the first grid, second grid and cathode circuits of the red electron gun. but if you dont know anything about this, just bring it to a qualified service technician. good luck!
Jan 21, 2007 | Sony KV-35S45 35" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
