Olevia model vcf-42fdv1u lcd tv screen displays menu,ch.#,program name,time,date, with no program picture(black screen)that says "no signal". No front led(should be green).Sound works sometimes.already Tried changing signal input(av1,av2,component1,ect.)Any help would be great! Thank You
The date and time appear in the lower-left corner of the screen, both when taking pictures and when reviewing pictures you've already taken.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
if just only raster then can not get any channel the tuner get bad which some parts get burned. if you don't have an idea how to replaced the parts just leave it to the trained tv technician or service shop.tuner is not too expensive unlike replacing an lcd monitor.
I will suggest you get the original (replacement) http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=RC-LTL
A universal (all in one) is good but you will not be able to get to menu....you will only have power, vol up/down ch /up/down
the link is only a suggestion the model of remote is RC-LTL...if you can find it for less by all means go for it
It's your power supply. have it taken care of ASAP before damage happens on the board where it can't be repaired, just replaced, "if they can find one".
more than likely the screen is cracked... this is not good news... try to check the warranty on the television as replacing the screen is not for everyone...
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
ALTERNATE SOLUTION:
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
