Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader door locked
F01 error code - door is locked - clothes inside
  • 2 more comments
  • mianeedshelp Sep 10, 2007
    Thank you to all who replied. The CCU board is bad and needs to be replaced. This machine was purchased in July 07 - so I'm a little miffed that this happened. Oh well - a new board has been ordered and should be in next week. The repairman was able to get my clothes out - so that was great!
    Thanks again everyone.
  • Anonymous Mar 13, 2014
    keeps showing up and wont go away the doors get locked and doesnt give cold water and the doors lock when i need to get my clothes out.
  • Anonymous Mar 16, 2014
    What Does Error Code F01 On A Maytag Front Automatic Washer Mean
  • Anonymous Mar 26, 2014
    received error code F01 and I can't unlock the door, What do I do?
  • 725 Answers
My Tech sheet reads F01 is a EEprom Error ? Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. ? Replace CCU board. Good luck and let mre know what you come up with
Posted on Sep 08, 2007
SOURCE:
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Getting the "F01" error, door lock is engaged too
Sorry but with no make ,model we can offer no help but you can try searching on Google make model error codes
Nov 09, 2015 | Ovens
Baby lock decorators choice model-error code F01
check with babylock customer service about the code
Mar 12, 2014 | Baby Lock Sewing Machines
Maytag Maxima Front Load Washer. F01 / E02 error codes. Power on, kicks off cycle, locks door, but will not call for water.
Tip the machine up & look inside up high, you
should find a bag with the diagnostic service
manual & it has the codes
Sep 04, 2013 | Washing Machines
Got an f 02 message, now the door is locked and will not open. Have unplugged and then plugged in again, still locked and cannot unlock and need to get clothes out. What is an F 02 error?
F01 refers to Long Drain Error.
Reason -
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
What Needs to be Done -
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose
and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 13, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
740 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
