Question about Toshiba 36A40 36" TV
Samsung Projection HDTV BLURRY!
The picture is just not clear at all. The picture is blurry but any words, ticker tape, etc that is on the TV is unreadable blurry. I have tried adjusting the convergence, I bought a brand new digital antenna, didn't help. Please help if you know what to do.
    Genius:
  • 1,153 Answers
Each projection set has focus controls in back, usually they don't move or go out of focus unless someone moves it, but in your case if you open the back you will see a focus block with 6 knobs 3 are for screen,I would highly recommend that you don't move this. Look for the focus and you will have to set each with the one color. Cover the other two and adjust.
Posted on Sep 16, 2007
Why is picture blurry?
Sounds like a misalignment problem. the lens has a specific optical plane the DLP chip must be positioned at in order to provide the proper focus on the screen. Try repositioning the board or adjusting the lens to clear up the fuzzy picture. Regards.
Aug 17, 2015 | Mitsubishi WD-73733 73" HDTV
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
My tv overall is blurry, but when I click menu to mess with the settings, only the picture of what I'm watching, and the highlighted word is blurry, but everything else is clear, video games and movies n...
Some of your electronics parts were worn out. Like capacitors may have leaks that need to be replace
as use stated that the word focus were very clear it means that your tube is still okay. or you adjust the focus knob on the compartment. To tune in the 3 colors.
Jan 01, 2011 | Toshiba 57H82 57" Rear Projection...
Blurry picture
convergence problem...very common. An excellent TV, well worth repairing!
Jun 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blurry picture with green and red halos around
Ur convergence is dead.Must replaced 2 Convergence ICS,and some or all the resistors.Know how to solders?Buy a convergence kit Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 16, 2010 | Samsung HC-P4752W 47" Rear Projection...
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry Screen
The bottom is blurry because some of the anti-freeze (clear ethelyne glycol) has leaked out. This anit freeze needs to be replaced or the CRT will get too hot and break. It will also clear up the picture.
Dec 05, 2006 | GE 46GW947 46" Rear Projection Television
Toshiba 36A40 36" TV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
