Question about Copystar CS-1510 Copier
"AP" ??? The screen keeps flashing AP which I think means "adjustment program" after I already changed the toner cartridge. What am I supposed to do now??
  • 33 Answers
The "AP" means the machine is adding toner, AP is adding powder. Let the machine cycle for a little bit, it should go away.
Let me know if you need more help.
Chuck
Posted on Jan 02, 2008
    Sniper:
  • 71 Answers
Do you have paper in the machine?
Posted on Sep 10, 2007
SOURCE:
What could be the problem with my printer? The toner button keeps flashing. I already replaced the ink cartridge on the printer, but the only thing the printer will allow me to print is the device...
Hi
If you have done more that 30,000 prints then I would think the flashing light means you need to replace the drum in the laser printer
Cliff Cook
MCP
Aug 03, 2014 | Dell 2230d Laser Printer
What is error code AP for this copier and how do I fix it?
ap means aging process or toner replenishment just check the toner if the toner cartridge is empty just fill a new toner
Nov 23, 2010 | OCE 3140 Copier
What does "AP" mean? It is flashing on the display.
AP means the Add powder. therefore the machine requires toner. replace toner the problem will be sorted
Aug 17, 2010 | Copystar CS-1510 Copier
Can't find glossary of what error codes there are and what they mean. Learned accidentally that "AP" is add toner. Is there a complete list?
When your copier toner run out then arise this signal.
change or replace toner cartridge.Insert new toner then remove this signal.
Thanks
with the best luck.Other problem please reply me.
Jan 27, 2010 | Kyocera KM-1505 Copier
MY 1810, i GET AN "ap" FLASH THAT changes to "OP' I find no paper jam in the trey nor the back..Mike
hi
the AP means that the copier needs more than one cycle to add toner.
This usually happens when the copier is used for a whiile after the add toner message comes on
Aug 22, 2009 | Copystar CS-1810 Copier
COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Shows an AP error. what does this mean?
Your copier is adding toner.Since they cant make a "T" with a 7 segment display, they used a "P" for powder.If it does not go away, replace the toner cartridge and wait a few minutes. Good Luck!
Apr 21, 2009 | Copystar CS-1510 Copier
Code ap
it means add toner (add powder (ap))
Feb 21, 2009 | Toshiba e-Studio120 Copier
The screen says AP -what does that mean
AP means that the copier is going thru a major toner cycle.
Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough.
The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken.
Sometimes the AP message will go away but make sure you have plenty of toner.
Feb 09, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Copystar CS-1510 Copier Logo
250 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
polytek
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
