Question about Panasonic CT-36D32 36" TV
My Panasonic TV
Once the TV is turned on it will shut off after a few minutes. I can get it to go back on if I take the cable wire off and push it back in were it connects into the back of the TV or if I leave it I will hear a clicking sound everynow and then like it is trying to turn itself back on which it does eventually. My cable goes from the outside to my cable box and then through my DVD player and then through an old VCR player until it end at the TV but I never had this problem until the last month.
  • Panacrud Dec 24, 2007
    We have a Panasonic CT-36D32 TV that will shut off with no warning and then after 2 - 8 minutes will just come back on like nothing happened.
  • pat44 Dec 28, 2007
    My TV turns itself off and then back on in about 3 minutes. When i take the back off of the TV it wont do it.
    Sniper:
  • 50 Answers
Many TVs, including some Panasonic models, have an Auto-OFF feature that will automatically turn the set off after a few minutes, if the TV thinks it is not receiving a video signal. By reinserting the coaxial cable, you are probably restarting the Auto-OFF timer inside the TV. There are several possible things that could cause the Auto-OFF to falsely activate. Try and change the coax cable going from the VCR to the TV, if you have a spare. If not, plug the cable from the cable box directly into the back of the TV. Make sure the TV is on the correct channel, usually Ch 3 or Ch 4. (Do not use the original cable that was running from the VCR to the TV, just in case it is intermittent.)
Posted on Sep 07, 2007
SOURCE:
Why does my panasonic tc p50st30 tv menu not work, tv will turn on but can not shut it off unless I unplug tv.
I would believe this to be a problem with the lvds cable that goes from your logic board to the main board. If your tv does not have a logic board, then it would have to be incorporated into the main board. A lot of times the connection gets loose on the main to logic board. If you reseat it, it may fix itself. If nothing else, you can pick up a logic board on ebay for around 25 dollars with shipping. It is usually very easy to replace. Most of the time, it's hidden behind the A board known as the Main board. It would probably take less than an hour to put in for someone not familar with the internals of a tv. Just MAKE SURE the tv is NOT plugged into the AC line.
Regards,
Joe Van Buren
Aug 06, 2014 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
Hannspree 28" tv video shuts off after on for a few minutes
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
Jan 12, 2013 | Hannspree HT09 28 in. LCD TV
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
TV cuts out
Loose connections on power supply and vertical IC.Resolder
Aug 04, 2009 | Panasonic CT-32D12D 32" TV
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic CT-36D32 36" TV Logo
250 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
