Question about Maytag 24 in. DWU9202 Built-in Dishwasher
Maytag Dishwasher Model: MDBTT59AW
When I press the cycle I want, i.e. Heavy Wash, the green lights go on but when I press Start nothing happens at all. After about 20 seconds the lights go out and that's it. I had also been noticing that lately it seemed to be taking longer and longer for it to run. The last time it did work (a couple of weeks ago) it stopped in the middle of the cycle for no reason leavint a glob of soap at the bottom. I also noticed that when I wanted to do the delay cycle that the green indicator lights - just to the delay, i.e. 2hour, did not light up any more. I tried selecting different cycles, i.e. Light wash and even just Rinse, and still nothing. I also turned the power to it off and back on hoping to rest. Nothing will work. I hope you can help me. Thank you.
  • Anonymous Dec 23, 2007
    SAME AS DENISE'S
  • dishwasher26 Aug 18, 2008
    Control pad is delayed over a minute to start. no water will fill the bottom of the dishwasher. all hoses were checked for blockages and all water valves are open??? Any suggestions???
  • 525 Answers
My research indicates that this is a control board malfunction, but with so many different descriptions of failure, I am left confused.
You may reference the link below to help isolate your problem.
http://www.repairclinic.com/0088_9_1.asp#Level1_9
Posted on Jun 05, 2008
SOURCE:
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Dishwasher won't turn on, lock light comes on when I try to start
my husband found the solution on line when he googled the problem. He read that the drain could have been blocked, or it said press the drain button. That did the trick, and now I have clean dishes! He didn't have to pay anyone to solve the problem which was nice.
Dec 03, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Jan 17, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Apr 13, 2007 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishwashers Logo
275 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
