Turns on then off
I have a sony grand wega kf60xbr800 i turn it on then after about 30sec it turns off the standby light flash 34 times and starts the clycle over.
  • 2 more comments
  • jetson Sep 09, 2007
    no it is not on
  • jetson Sep 10, 2007
    I figured it was a safety feature and the flashing 34 times was a fault code like the xbox. I was hopeing someone would no what is faulty I think it might be the fan but just guessing thats why I'am here. oh ya if it had a warranty that would have been my frist call.
    where to find fault codes
    Sergeant:
  • 279 Answers
The only reference I can find to a 34 blink code says it means the power block needs to be replaced. You can order that here: http://www.nexttronics.com/catalog/sony/1/146851015.htm#%3E%3Cbr%3E%3Cbr%3E%3Cform%20method=post%20action= However, I can't be sure that's accurate, so I don't know if it's a good idea to invest that much money into replacing it.
Posted on Sep 11, 2007
    Scholar:
  • 133 Answers
It's likely to be a fault with the TV, the flashing light may be a fault code. Check your warranty out with the manufacturer, if you have a valid warranty, get it returned and repaired. If you do not have a valid warranty, ask them what the standby flashing 34 times would signify, they should give you some insight as to what needs to be done to fix it. It's likely to be a safety feature, in which the TV shuts itself off to prevent any damage.
Posted on Sep 10, 2007
    Master:
    Sergeant:
  • 461 Answers
Check your sleep timer it is on or off
Posted on Sep 09, 2007
SOURCE:
Sony Grand WEGA KF-60XBR800 Service Manual
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Apr 29, 2014 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony grand wega turns off & o ever 30sec flashes green light
it's a power failure.try to replace the regulator in power supply board.
Sep 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Turns off turns on standby light flashes
replace the lamp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Apr 24, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Ekse
