Question about Akai LCT3201AD 32 in. LCD Television
Sound when I use the dvd portion of the system-I can barely hear the sound-also can you explain to me surround sound and am I supposed to add additional speakers to my tv set to get that-also what attachments do i need to add additional speakers-please keep in mind when I switch from Dvd(the player is built into the Tv) back to regular TV-the sound is loud enough and goes up to +100-any other info on setting the correct sound would be helpful
    Genius:
  • 1,139 Answers
You may have your audio presets on your DVD too low. check your menu to make sure those presets are correct. As for Surround Sound it is a sound technique that involves having multiple speakers to give the impression of moving sound, not just hearing from the left or the right as in stereo, but hearing the way you are exposed to in real life sound moves around you this combines the doppler effect from many directions at once, example: as a car move towards you with its horn blowing the sound gets louder as it passes you the sound gets lower however, each of your ears hears the sound diferently, thats how come you can tell if the car is to your left or to your right vs coming straight at you and as it passes you, you can tell if the car is on your left or right from your rear. Surround sound is an attempt to do this without actual movement. I hope this helps.
Posted on Sep 08, 2007
SOURCE:
I have my laptop hooked up to the z506 surround sound speaker system. Since I don't have a good sound card or multiple ports to support 5.1 surround sound, the rear speakers do produce a bit of a...
Check that your mic settings in the Volume control is not maxed out. Turn the mic off and see if the fuzziness clears up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 17, 2011 | Logitech Z506
I need a LHT854 LG surround sound dvd manual could one be mailed to me?
Please click hear or hear to get the Manual for the unit. Please let me know if you require any additional help.
Apr 30, 2011 | LG LHT854 Theater System
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
Audio and sound while watching DVD'S
does your reciever/ amp have a pof digital input ??? i would try upgrading to digital signal before anything!!!
Mar 10, 2008 | Audio Players & Recorders
DVD Volume
Could be the audio format for some movies to enhance surround sound, but could also be a mixer problem on the audio portion of the TV input...accordianman
Feb 27, 2008 | Akai LCT2701TD Television
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Akai LCT3201AD 32 in. LCD Television Logo
91 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
