Sewing Machines Logo
Anonymous Posted on Aug 21, 2013
Good Housekeeping Zig Zag Sewing Machine 142-b 422B350922
  • Anonymous Aug 21, 2013
    I need a manuel for this machine
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Aug 22, 2013
Level 3:
Answers
7365
Questions
Helped
1741644
Points
19451
What problem are you having with the sewing machine?
5 Related Answers
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Anonymous
  • 15 Answers
  • Posted on Nov 20, 2008
SOURCE: how to oil my sewing machine
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
Anonymous
  • 323 Answers
  • Posted on Feb 16, 2009
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
silly01
  • 18 Answers
  • Posted on Aug 16, 2009
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Anonymous
  • Posted on Jan 23, 2010
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
1975/76 Kenmore sewing machine will not zig say stitch
There is a zig zag gear in the top of the machine that breaks somertimes and thus prevents the machine from working correctly. Or it could be the machine hasnt been cleaned and lubricated properly.
Good Luck
2answers
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
My jones sewing machine wont stitch straight just zig zag tried moving parts
Probably the zig-zag mechanism has seized from lack of oil/cleaning. Pick up fresh, good quality sewing machine oil or Tri-Flow Synthetic Lube and apply a couple drops every place where metal rubs against metal (including the zig-zag mechanism). Do NOT oil any rubber or leather parts (belts)!!!
Then apply heat from a handheld hairdryer. Repeat until it loosens.
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
1helpful
2answers
How can i find a manual for a universal sewing machine kzm 022951
Search the internet for:
Manufacturer + Model + the word "Manual"
1helpful
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
3helpful
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
