Question about Maytag MSD2756G Side by Side Refrigerator
Dispenser Panel is not working
Hi, after 8 hours of power outage, our refrigerator dispenser panel doesn't work at all. We tried to troubleshoot by checking if the switch is working properly. When we opened the freezer door and pressed the switch, the water indicator would lid for a quick second. Any clue why it's not working? Is there a fuse that we have to change? Wiring to check? Thanks.
  • 291 Answers
Coundnt bring up anything on the model # Try Takeing cap hedge off freezer side unplug door power plug for 20 minutes see if that will reset dispence board .... works on ge... havnt tryed it with a maytag
Posted on Sep 08, 2007
SOURCE:
Why doesn't dispenser control board work?
the main board could have failed and also caused the dispenser board to not work. What is the model number of the refrigerator?
APPLIANCE 911
Jan 21, 2016 | Refrigerators
Whirlpool refrigerator model# gs6nhaxvk 06...fridge and freezer works normal, but water dispenser and lights not working and the door ajar alarm is beeps.Please advise.
if your freezer door is not closing properly you will have problem with the dispenser because the light switch activate the dispenser is a safety device checked why your door is staying ajar. can be gasket or what i have seen is that after cleaning the refrigerator the customer don't put shelves in properly causing shelf to push against door
Dec 20, 2014 | Whirlpool Refrigerators
Whirlpool GD25FFCHT01 dispenser not working
It might also be the cable that connects through the hinge door to main unit.
Feb 08, 2013 | Whirlpool Refrigeration White Side Trim...
GE Refrigerator Ice and Water dispenser stopped working after power outage
More than likely the user interface board that controls that portion of the machine is probably bad, or, worse case scenario the main control board which has the overall say so for the machine has gone out which isn't uncommon either. My best advice is if your going to do it yourself buy your parts from www.repairclinic.com because of their return policy which you can return any part you bought even if installed/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | GE GSH25SGRSS Stainless Steel Side by Side...
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is working.
I have the same problem. I have to turn off the power button on refrigerator and turn it back on again. Then the ice dispenser and water dispenser will work again. It happened very often.
Oct 07, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Front door dispenser panel stopped working, lights are off.
HI. the dispenser circuit board(s) will need to be replaced. there are two boards that work in unison. replace them both. this will fix your issue.
May 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
426 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
