Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Won't Connwct revisited
I have a Acomdata 2500hes-72. The external hard drive is partition ino 2 partitions - "data drive" and "CD-part". I can see the cd-part" in Windows but I can't see the data drive where I have stored "system backups". I would like to reformat the whole drive but I can't see the whole drive. Any suggestions? thanks
  • dhs13 Sep 08, 2007
    I only see 1/2 of the drive so I can't format the part I don't see.
    Since I can't see 1/2 the drive, what good is formatting it.
    Show hidden files was enabled.
    Problem Solver:
  • 13 Answers
Make sure that the folder settings are set to Show hidden files, also if you want to format it then just format it and it should clear every thing unless you wanted to keep the files first.
Posted on Sep 08, 2007
How do I eliminate partitions on external hard drive?
in windows xp/vista/7 click start, right click (my)computer, then select manage. Open the storage option. you can then manage your partitions.
Sep 07, 2012 | Acomdata PHOTON 2.5 (PHD080U2E54) Hard...
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
I just purchased a external hard drive case to use bc i was upgrading my hard drive to my laptop. now my new laptop has the bigger hard drive and my old hard drive that came out of my laptop reads 4...
It sounds like your old laptop drive had 4 partitions on it.
If that is the case and you want it to be only one partition then you'll have to back up anything you want to keep in those partitions and reformat the drive as one partition.
You can reformat the drive using the Disk Management utility in Windows.
Dec 05, 2009 | Acomdata 250GB External Firewire HD 250 GB...
Drives - size
Resizing partitions is easy with the right tools, and near impossible without them. You will want to first
get a good hard disk imaging program along with an external hard drive (some drives come with imaging software bundled with the drive) a few examples would be Norton Ghost, Acronis True Image, Dantz Retrospect, Powerquest Drive Image and so on. There are even some good freeware and Open Source alternatives. By imaging your c: drive to a USB external drive you can safely edit your hard drive partition tables and then put everything back with no reinstalling Windows or losing any data. You will need to have a bootable recovery CD on hand when it comes time to restore the image from the USB drive to your system drive. I would suggest that you first copy all files you want to keep from the d: e: and f: partitions to the c: partition, then image the c: partition by itself to external drive. Take note of the c: partition type I.E. FAT32 or NTFS. Make a bootable utility disk (Ultimate boot CD available from for free) is one, an emergency boot floppy from Windows 98, ME, NT will work also. Boot with it and run FDISK to delete extended drive letters D E F and then their partitions and then delete the C: partition and finally create the C: partition with all available space and make it active. Replace the utility boot disk with the recovery boot cd, restart the computer and run the image recovery to restore everything back to your now 80gig system drive.
Jan 07, 2009 | Biostar NF325-A7 Motherboard
I/O Error on Acomdata External Hard Drive
Go into Control Panel/System/Device Manager and look for yellow exclamation marks. Delete any you find. Reboot your computer. Connect the external hard drive and turn it on. Let Windows discover it. If it asks for the driver, put in the CD that came with the drive.
If this will not works means there is some problem in your HDD partition and you need to format them...
if you donot want to lose any data then use any recovery software to recover data from your HDD.
Good Luck!!
Oct 14, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
No ned to check in that.
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
81 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
