Question about Motorola Mobility RAZR V3
Can only receive calls and turn the phone on and off! cannot dial out, access my contacts, ect., keypad not working at all.
I can only receive calls and turn my phone on and off. The key pad is not working at all. The only button on the keypad that works is the on and off button. Sometime when I press different keys I get a message on the screen saying that my Voice Record Memory is Full! I've tried removing the sim card and battery several times and even leaving off overnight.
  • Sam Berman
    Sam Berman Jan 10, 2012
    I found the solution at another web site, finally. Here it is.... Remove the battery and replace it quickly -- within 1 second. The phone will turn off and turn back on by itself and you can go to settings and remove all the voice recordings and your phone will be back to normal! I was so shocked when it worked for me!
    New Friend:
  • 53 Answers
If you are comfortable taking part of the phone apart there is something you can try. Remove the two Torx screws right below the battery. Gently pull the plastic cover loose. There will be a cable that connects this portion of the phone to the keypad/LCD/etc. Clean the connector on this cable and the connector it was plugged into with 99.5% Isopropyl alcohol. Reseat the cable and the part of the phone you removed and replace the screws you removed. If this does not work the keypad flex on the phone is probably damaged and will need to be looked at by a repair center.
Posted on Sep 07, 2007
  • Sam Berman
    (Sorry, I didn't put this in the solutions area before) I found the solution at another web site, finally. Here it is.... Remove the battery and replace it quickly -- within 1 second. The phone will turn off and turn back on by itself and you can go to settings and remove all the voice recordings and your phone will be back to normal! I was so shocked when it worked for me!
SOURCE:
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Panasonic cordless phone model KX TG 5771 dial got locked. Password in not known. we can receive calls and we can talk also. we can not dial the numbers.
My cord less Panasonic phone dial locked not able to dial please give solution how to normalise the dial lock.
Dec 08, 2010 | Panasonic Lands Phones
Ok im trying to transfer my work phone to my cell phone so i can go home and not have to sit up here all night. and i cant figure out how to do it.
  1. Pick up the receiver on your work phone and wait to hear a dial tone.
  2. Dial *72 on your work extension phone keypad. You may hear a series of four beeps that indicates the system is ready for you to enter the phone number to which your calls will be forwarded.
  3. Enter your cell phone number including the area code on the keypad of your work extension phone.
  4. Hang up the receiver on your work phone.
  5. Test the call forwarding by dialing your work extension phone from another phone. Your cell phone should ring. If it does not ring , repeat Steps 1 through 4.
Read more: How to Forward Calls From My Work Extension to a Cell Phone ' eHow.com http://www.ehow.com/how_6239419_forward-work-extension-cell-phone.html#ixzz16L3AMu3K
Nov 25, 2010 | Office Equipment & Supplies
I cannot access use of my keypad. When sliding
keypad is complaint it need to be changed better contact a cell phone service center... kpfrlewajveq0aaaaasuvork5cyii%3d
Feb 04, 2010 | Nokia Cell Phones
IPhone keypad not working: touchpad works fine otherwise
did you get your phone working? reboot by press and hold the sleep and home buttons until the apple appears.
Jun 05, 2009 | Apple iPhone Smartphone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Possesed phone
Sounds like some sort of short in you keypad, possibly some water or liquid has come in contact with your phone?
You should seek service IMO.
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Keypad problem
try restoring or reset settings
Mar 11, 2008 | Apple iPhone Smartphone
Motorola Mobility RAZR V3 Logo
100 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
