Is this a laptop, phone, or a pc keyboard?
If it's a PC keyboard you might be able to pop the key out and clean under it. I have went as far to clean PC keyboards in the dishwasher. (low heat, no soap, no high temp dry... and then shake all excess water out... and let dry for a week or two.. before you plug it back up.) But do this at your own risk.
If this is a phone, and it is on a touch screen, then try going into settings and changing from samsung keyboard to default android keyboard.. or vice versa.
SOURCE: keyboard problem
Do the following steps:
If still problem just Ask me
Thanks
Iqbal
SOURCE: the letter w is appearing after every letter I type
I am assuming you are using XP and not Vista, follow these instructions to check the keyboard
Go to Start/Control Panel/Regional and Language Options/languages/settings
Look at the top drop down choices and make sure the keyboard input text is in the language for your country
Vista is a similar operation. Just follow your nose
SOURCE: bluetooth activates by itself, random letters appears when typing
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
SOURCE: I have a keyboard problem examples; when I type m
it sounds like its on its way out try ebay for a replacement also check the keyboard conection.
SOURCE: different letters appear when typing a certain
I see that when typing in on the keyboard some letters appear as well like for "s' the letter "w" shows up as well.
Was there any liquid spilled on the keyboard? if none then you can try cleaning OFF any unwanted software on you computer, then perform a disk defragmentation on the machine just to have everything in proper order for the windows side.
After doing what was said above restart the computer and try the keyboard again if still the issue is the same, i suggest that you back up any personal stuff like pictures and emails if ever because reformatting the Hard drive and windows back to factory defaults will be next to see if the issue will still be the same after reinstalling windows back to defaults.
If the issue is still the same after reinstalling windows then this is going to be considered a hardware failure to the keyboard and replacing the keyboard will be the next best thing to be done.
Unless Liquid was the cause then the issue may differ if the motherboard was the one causing the letters to type in with other letters which is not common.
