Question about Panasonic DMR-E55 DVD Recorder
Panasonic DMR E 55 cycling on/off
The recorder powers up,goes through the self test,attempts to read the disk but then seems to turn right off(blank display). It then comes back on and repeats the cycle etc.
  • Anonymous Nov 07, 2007
    none
The problem is the disc not the machine, put a new disc in
Posted on Nov 05, 2007
  • 3 Answers
Just posted the all too common self check problem. you all seem to have sorted this some time ago, shame Panasonic dont seem to want to acknowledge they have this problem. I will be ordering the STRG635 although my eletronics knowlege stops just after fitting plugs, so removing the old one & fitting the new one (hell, even finding the old one) should prove interesting.
Thanks to all those who have taken the time to post solutions here,
Pete
Posted on Oct 29, 2007
    Problem Solver:
  • 6 Answers
Likely to be the power control IC (strg6353?) in the primary side of the PSU. You'll need an engineer to replace this component.
Posted on Oct 27, 2007
See this thread
http://www.fixya.com/support/t122832-powerdown_after_few_seconds
Posted on Oct 14, 2007
SOURCE:
Dmr-ex85 shows u81 code and is not functioning at all, says please wait but eventually just goes onto error code. no buttons will function?
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
Jul 12, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR E65 cycling in self test on start up
Check the IC in the primairy power supply,common fault.
Jul 22, 2009 | Panasonic DMR-E65 DVD Recorder
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Jan 15, 2008 | Panasonic (DMR-ES45VS)
Panasonic dmr es10
Some DVD recorders don't like certain types of media. Does this happen with all blank dvd+rw disks or just with that specific brand? If it's that brand then you should just use a different one.
Jan 07, 2008 | Panasonic DMR-ES10 DVD Recorder
DVD Ram recorder
Mine, a Panasonic DMR-E80H, didn't like some of the Ram disk either. Either I was trying to erase it or just read it and it would shut it self off and go into recover mode.
So, I pulled the plug overnight. Then, first thing after I plugged it back in was to eject the disk before it tried to read it. Once the disk was out. It stopped going into recover mode.
Good Luck.
Dec 02, 2007 | Panasonic DMR-E80H DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Dmr e85 will not start up
Hi Audi,
Try unplugging the hdd & then turn on the dvd recorder & wait for about 5 minutes.
Then unplug the dvd recorder & plug in the hdd & turn back on the dvd recorder to see if that fixes the problem.
Oct 18, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-E55 DVD Recorder Logo
321 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
