Question about X2Gen MG19MY 19" LCD Monitor
Color Problem Today I turned the pc on and the monitor is whole red! I didnt do anything i just turned it on and sudenlly everything is red. I tried the color adjustment or auto adjustment but it doesnt seem to work. can u help me with this?
In rare instances it is sometimes the 15 pin connector that connects on the computer end. Could be at the monitor end of the same cord, if it is a connector and not hard wired to the inside. Check both possible sides for bent pins.
I once went through an extension cable and had to remove it as it was bad connections and I'd have constant color changes drifting in and out. Sorry, but most likely it is just a cheap monitor on the fritz.
Posted on Dec 07, 2007
SOURCE:
Hi, My monitor will once in awhile go from the warm white color to a slightly red or pinkish color. The monitor is about 5 years old and the model # is AL1913. Any thoughts? Thanks. Don
Red or pinkish cast on the whole screen? You may want to check the VGA connectors and pins at both ends. Also try it with anothe PC to make sure it is not video problem in the PC.
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Dec 15, 2010 | Acer AL1913 19" LCD Monitor
Whole screen has a light blue tint. we've tried adjusting the color on the menu and that didnt help. also, we went into control panel and adjusted color there and that didnt help either
You have either bent pin or the the video connectors are not properly attached to the PC or the monitor. It can also be the video card itself, but check all the pins at both ends of the video cable first.
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 19, 2010 | Dell E176FP 17" LCD Monitor
Ok i been searching for a solution and i have gotton nothing....so i thought i would post my problem, i hope it can be answered. i have a viewsonic monitor and almost ever since i'v had this computer, the...
1) To unlock the monitor: http://www.fixya.com/support/r4554177-viewsonic_monitor_lock_unlock
2) I am not sure about the red light, are you taking about the power light or you are getting red tinting cast on the screen.
3) The monitor is old will more likely to have problem in the power supply by now due to bad caps and it can make the monitor act strangely. I am not sure what you mena by loos power cable.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
I would not suggest you to try to take it apart since there are high voltages inside that can kill you.
Sep 27, 2010 | ViewSonic VA721 17" LCD Monitor
My 19 inch ViewSonic monitor shows red /voilet
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Apr 25, 2010 | ViewSonic VX912 19" LCD Monitor
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
2 problems, monitor color and update possible?
well it sounds like the color scanning chips in the monitor are going<have gone> bad. If you have access to another monitor I would hook it to your system and see. XP may run, depends on your processor speed and RAM amount, also graphics can be an issue in XP
Apr 04, 2009 | Computers & Internet
Colors are messed up
If You are using a CRT monitor (older Monitors similar to a TV) It may be time to replace it
Also you can try right clicking in a empty space on your desk top
go to properties>settings and check to see if your color quality is set to 32-bit
Double check you monitor connection
If all else fails your video adapter could be failing or you Monitor(VGA/DVI) cable is going bad
Jan 29, 2009 | E-Machines eMachines Desktop PC
Print images look like a rainbow, going from blue to red to blue to red etc.
I am on my way to a couple of appts. I waill answer early afternoon, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 06, 2008 | Ricoh Aficio CL3500N Laser Printer
Cannot change color on monitor
check the R.G.B voltages at the crt base.if it is ok the crt may be defective.
Apr 04, 2008 | E-Machines eMachines Monitor E15T4
X2Gen MG19MY 19" LCD Monitor Logo
82 people viewed this question
Top X2Gen Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
