Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer prints always only a blank page
When I am trying to prints a documents (no matter from which software: Word, Excel, Notepad, Adobe Acrobat, Image, etc.), the printer prints only a blank page. Using the HP tools, the cartridge alignment printed OK, the test page is printed OK. Printing from another PC is working fine. I have tried to uninstall the driver, remove the driver files from the windows directory and reinstall did not helped. Does anyone know how to solve it (without re-install the windows) ?
  • kobymiz Sep 08, 2007
    The problem is solved!!!
    I have followed the last suggestion without trying the other suggestions. I have installed the printer usign Microsoft default driver and it solved the problem!
    Thanks jackboy for the help!!!!!
    Koby
  • toys2 Jan 11, 2009
    Printer Prints Blanks- Test page works fine and copier works fine bu tcan't print from file
    Genius:
  • 2,985 Answers
2 more things to try. Assuming it is USB Change USB port. Re boot the computer. Replace the cable. Reboot the computer. Coming back to the driver software. Go to Start /Printers and Faxes/Install new printer Leave what is there in place When the Wizard comes up and asks CD or Select from list Choose select from list - then go to HP and your model and simply load the generic driver. Try each alteration one at a time Tell us what you get.
Posted on Sep 07, 2007
SOURCE:
Can't print pdf documents- I get a message that I must install printer. I am able to print other word docs, just not pdf.
It could be your adobe acrobat reader responsible for PDF documents
If you can print using other applications definitely it has nothing to do with printer.
Try downloading latest version of acrobat reader from adobe website.
Unintstall the acrobat reader software from your PC in ARP (add remove programs)
reinstall the latest version of adobe acrobat reader
Try links below it may help you too
http://www.adobe.com/products/reader.html
http://get.adobe.com/reader/
Hope I help you a bit
Thanks
Mar 28, 2011 | Office Equipment & Supplies
I can't print pdf
This is not a printer problem ... this is a software problem. You don't mention your operating system so it is difficult to go much further. You can check your hardware compatability ... likely not the problem since you don't say you can't print other formats, yet, still a possibility. For Microsoft operating system ... check here: http://www.microsoft.com/whdc/hcl/default.mspx
I suggest you check your drivers to make sure everything is up to par.
Sep 20, 2010 | HP LaserJet CP1515n Printer
Will not print from microsoft word, excel or any internet program but will print from notepad and also test pages
download a adobe acrobat professional first then everytime you want to print form ms office print it first on pdf then print your pdf to your printer,
or you must try to restore your printer to its default settings
Jun 28, 2010 | Canon PIXMA MX310 All-In-One Printer
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
I need to combine Word documents and Excel files into one pdf A-4 size document. The Word documents come out A-4, but the Excel always comes out as letter size??
First you will need to create separate .pdf files then you can combine files with Adobe Acrobat through command Document/Insert Pages.
Oct 16, 2009 | Computers & Internet
Printer prints blank pages from notepad, word, and excel.
Hi tim8094
Obviously there is nothing wrong with the printer, because you are able to print from the Internet.
Before attempting to print from word, excel etc, make sure you have the correct printer selected (check it through FILE MENU -> PRINT ->PROPERTIES)
Do a print test by typing just couple of words -may be in different color-
Best of luck
luciana44
Sep 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
Can't print from Adobe Acrobat
You did update the printers software to VISTA drivers, correct?
Nov 10, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
214 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
