FixYa.com
Tags:
OEM Systems PIXMA iP3300 Photo Printer
Printer won't recognize ink cartridge (by 6 users)
posted by babysamsmom on Sep 07, 2007
My NEW Pixma ip3300 won't recognize my Cyan ink cartridge. It was working fine and then after a few prints (cartridge is still full) the cartridge isn't recognized. When I take it out and reinstall it the cartridge lamp goes on, but when the printer resets itself the cyan lamp goes out. I am aggravated and not sure what to do. I don't want to have to buy a new cartridge when this one is full. I have also turned the printer on and off and even restarted my comp... nothing works. I have taken out the print head and reinstalled it as well... didn't work. Any advice would be appreciated as I don't want to fight with Staples (where I bought it) to get it fixed.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by doyledog, posted on Aug 16, 2008
I had the same problem (magenta cartridge light not lit, then Ok when removed and re-inserted , but eventually that didn't work anymore) with my first IP3300 and took it to the authorized repairer in Luton (postage would have been silly money ,and I was driving past.)
They sent me a new one in the post , but now a few months later , without a lot of use in between , the same problem is starting to re-occur .
I'd say that this was a common problem from what I've seen on the net.
If Canon don't sort this out under warranty again , I'll buy an HP printer for £30 rather than spend £10 on another poorly designed canon ink tank.
Comment by Kirra, posted on Feb 20, 2008
I have the same problem ink cartridges are full yet the yellow & blue cartridge lights are off
Comment by Guest, posted on Dec 23, 2007
Same problem with the yellow cartridge.
I have decided, from now on I will bust this printer refilling the used cartridges using cheapest OEM inks and after that WILL NEVER AGAIN BUY A PRINTER THAT COMES WITH MEMORY CHIPS ON ITS CARTRIDGES.
MFs tried to do this in Europe but got sewed for monopolism and EU printers are forbidden to have those chips but here in america we get screwed all the time.
I was a huga fan of Canon - no more!
Comment by Guest, posted on Nov 26, 2007
Same as above, Cyan cartridge red light goes off and the feed button on the printer starts blinking.
Comment by Guest, posted on Nov 20, 2007
My Canon pixma iP3300 won't receognize a new ink cartridge. I have taken it in and out, fiddled with it and made a few more copies, but now it is simply not working. I don't have time for this. I can't put it through the cleaning cycle because it says there is an ink problem. Ahhhggg.
Best Solution
posted on Oct 24, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Guest again:
Called Canon.   It is a defective cartridge and they are going to send me a new one once I fax in my receipt for the purchase of the printer.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 22, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I had the same problem with the yellow cartridge.   At first when I resinserted it, it would solve the problem, but today even that didn't work.
I did solve the problem by clearing all print jobs, turning the printer off and then on, and then running a cleaning cycle on the color nozzles.   I don't know why this fixed things, but my yellow was suddenly recognized without any further fiddling.
Can you Help with these Printers problems?
Printers
we print 3 com slips
we print 3 com slips on a page... Answer This...
Cannon Pixma 3300 printer
After computer crash, came to... Answer This...
CONTINUOUS FLOW INSTALLATION...
this is jhong just bought canon... Answer This...
cannon pixma ip3300 printer
from pressing the print icon.... Answer This...
printer fail to recognize the...
My NEW Pixma ip3300 won't... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
