Question about Stanton C.304
Stops reading mid song
After approx 2-6 mins of playback, the cd deck lcd display goes blank (but remains blue, i.e. doesn't lose power) and then READ flashes as if the player can no longer read the cd and the player locks up until i turn it on and off. I have checked all the power cables by changing with my other identical deck and the same thing happens. I suspect that because of the time period before it stops working it could be a fan problem and maybe tripping out overheating but I need help as it is no longer under warranty. Is this something that sounds familiar?
  • 1 more comment
  • Anonymous Jan 02, 2008
    yeah it has happened with mine quite frequesntly... now one is totally unusable... i was told it is a very common fault... if not the most common fault with the C304... :-(
    i am taking mine to a stanton dealer next week to see what they have to say and i will let you know if i rememeber
  • dazzafox Feb 16, 2008
    Yep me too
  • DJ LOU Mar 23, 2008
    I have two with the same problem. what a waste of money.I would like to get them fix.
  • 3 Answers
I KNOW THE SOLUTION TO THE PROBLEM IF YOU'VE STILL GOT THE PROBLEM EMAIL ME ON DJWOLFUK@HOTMAIL.CO.UK
REGARDS!!!
Posted on Apr 25, 2008
I also have this problem
Posted on Jan 24, 2008
Man please let me know what they say, i have this problem too. I suspect it has something to do with the laser to read the cds....
Posted on Jan 07, 2008
Stanton 304
hello sir
Feb 25, 2008 | Stanton C.304
The door is not opening easily and tape runs for approx.2 sec. during playback then right hand reel table stops and the deck switches to stop. FFW/REW is OK.
i have same problem with 2 sec playback then stop on technics rs tr232. need advice and enlightenment so repair guy doesn't rip me off.
Nov 08, 2010 | Audio Players & Recorders
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Fuze locked up and failed this morning
attach the USB cable then Press and hold for 20 seconds the ON button & the Play button(>||)
Feb 05, 2010 | SanDisk Sansa Fuse MP3 Player
Firmware install on Pentax ist DS. Had Ver2.0 & everything worked fine. Simply wanted to upgrade to V2.02 to used SDHC cards. User Power AC and install ran approx 90 secs and displayed showed half way...
You need to go to the support section of the Pentax website and engage in a live chat with a service tech using your computer or even a phone conversation to resolve your problem.
Oct 10, 2009 | Pentax *ist DS Digital Camera
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Stanton C500 Dual CD Player
hi, check that when the right side tray closes the screen must show up READ or DISC CHECK. the behaviour must be the same as the left side cd deck. if loading is faulty then the cd tray is out of alignment or sensing swithches are faulty. if disc is loading then u have a laser pickup problem or the laser ribbon cable is intermittent or the spindle motor is tired or the laser lens needs accurate cleaning. cheers.
Aug 05, 2007 | Stanton C.500 Dual CD Player
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Stanton C.304 Logo
166 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
