Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine heating element
While using the washing machine the heating element has fallen out and flooded the kitchen. The element is not faulty i just need to know how it fits back into the washer, where it fits inside the machine it has a rubber seal but it does not seem to fit all the way in
Remove the front panel of the machine, remove the element and slacked off the centre bolt, apply a layer of clear silicon to the rubber seal refit tighten centre bolt leave overnight and test the following day, this will resolve the problem.
Posted on Sep 08, 2007
SOURCE:
Washeing machine not heating up
It sounds like either the cable's have rusted off, fallen off the water heater element. Or the Water heater element has failed.
Watch this link to get the repairs done
How to replace washing machine element on Hotpoint washer
Mar 04, 2014 | Hotpoint Washing Machines
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Hotpoint Washing machine keeps flooding kitchen
For the age of it, you can either replace it or get it fixed. I would personally get a quote first for repair.
May 18, 2012 | Hotpoint Aquarius WT540 Front
F 03 showing on machine
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Jul 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Error code on washing machine wf640
have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Mar 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Cold drying cycle in my haier
this is usally that the spade wire connector has fallen off the heating element remove the top of the machine and, check
May 28, 2009 | Haier 14.3 lb. Washer/Dryer Combo
We have a new maytag kitchen stove model merh865raw. We have had it about 2 weeks. Now the surface indicator light will not light up when in use.
If the indicator light you are referring to is the 'surface hot' light then either the element has failed or a connection to the element has fallen off.
If the indicator light you are referring to is the 'element on' light then either the corresponding control switch has failed or a connection to the switch has fallen off.
It may be possible the lamp has failed..although never have seen one fail yet.
Jun 08, 2008 | Kitchen Ranges
Hotpoint Ultima WF860 Front Load Washer Logo
99 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
