Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Camara won't come on
My camara was working fine. Someone left it on and the battery ran down. I recharged the battery but the camara will not come on. Could it be the battary?
I have the same problem that just occurred with a SD400. Tried the battery in my newer SD1000 and it's not the battery. Noticed that there is a tiny tab that prevents the camera from coming on if the battery cover is open. Check that little black tab to make sure it didn't get broken off or damaged, otherwise it might be fooling the camera into thinking the cover is still open. That didn't solve my problem, but it's worth ruling out.
Posted on Sep 08, 2007
  • 641 Answers
It could be the batteries. To be sure about it, try your batteries in another appropriate appliance. Good luck!
Posted on Sep 07, 2007
SOURCE:
Camera wont come on battery gets really hot
if it is a digical if so the batteries have to be rechargeable and be over 1000 because the rest just arnt good enough . because of the technolgy in the camara , and because of what it can do do . the batteries have to be the best . their will be more power comeing out of the camara and excceds the battereis. its like a mobile phone , the phone is a 16 volt batteri and you plug a 5 voult charger in the phone . it gets realy hot because their is insufficaint charger for the volt . we wiill have almost blew the charge on the batteris aswell as the connection on the camara or ie [phone]. leave for 24 hours and then try the rechargeable energizer 2000 plus is one of the best .replace the old for new and try the enegizers
Mar 30, 2012 | Sanyo VPC-T1060 Digital Camera
My brench of camara name Powershot SD1300is digital. when i turn on with my canon camara i see lens error will shut down outomatic restart camara.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 23, 2011 | Canon PowerShot A560 Digital Camera
My l200 camara lens is stuck
huSh now :( I remember my former camera.. XD
Lens errors are fairly common. Usually it's sand or grit interferingwith the lens extension mechanism. Or the camera's been dropped withthe lens extended. Or the camera has been powered on, but the lens hadbeen blocked preventing its extension. Or the battery ran down with thelens extended ...
Here's some things that you can do to try to correct it. They only seemto work for less than 50% of the lens errors, but if the camera is outof warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12...
hope this will help ya out
Jun 06, 2009 | Samsung L200 Digital Camera
Camara on blackberry phone does not work
You can clear the memory by doing a soft reset - Hold down Left Alt, Right Shift and Delete keys simultaneously for a couple of seconds which will clear the memory.
Let me know how you get on with the above.
Jun 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Try turning off the phone and then removing the battery for a few minutes. Replace the battery and then then let the phone reboot, it should work fine after it reboots.
May 31, 2009 | AT&T Blackberry Curve 8300 Smartphone
My olympus isn't turning on
Try putting in regular batteries and see if it will turn on. The rechargeable batteries might be over-taxed and won't recharge. My Olympus camera works just as good on regular batteries as on the rechargeable ones. It is easier to come up with regular batteries than having to always run to the docking station to recharge the original batteries.
I hope this works for you.
Mar 20, 2009 | Olympus Camedia Stylus 300 Digital Camera
Buying a Camara
Hey Dussan,
Three camera's that might work for you are the Nikon P80, Panasonic DMC-FZ50K, and the Sony DSC-H50. All three of theses camera's have a 12x optical zoom and up, they are all 9 mega pixel and up, they all have movie mode, they all use lithium-ion batteries, and they are all around the same price as the Canon. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Cameras
Camara won't stay on.
go to the HP website and install the firmware on your camera. it contains the instructions for it, and they claim that it will solve the battery life issues. i haven't had this problem, but in searching for a solution for my problem, i ran across that solution.
May 05, 2008 | HP Photosmart M425 Digital Camera
Help need to fix camara for work
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Sep 07, 2007 | HP Photosmart M22 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
63 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
