This is one year old machine. Just two days ago its was out of warranty and I am having these problems. 1) If plugged-in: Run automatically on its own. and displays the error code: F 2) Washing machine runs but keeps "Beeping" Called Sears and same story: costs $200. Wouldn't honor the warranty.
Saw the tech pull clothes from under the basket. Must have sucked them in. Find it hard to believe that all these panels are going out at the same time. Remove basket and garments from under.
That would the user interface board (touch panel)behind the dash. Sorry, but not a cheap fix at all. Maybe search Ebay for the part, sometimes you can find it cheaper. Very expensive part and repair. Good Luck to you. Jim
My washer will not respond when I select a type of load. The only digital thing that works is the power off/on. Please help
My problem is that when you start the machine it runs for a few seconds and then it starts beeping and blinking F1. You have to hit stop and then start again a few time before it run right. And then it happens agian at the rinse cycle.Lucky for me I have exactly 3 days left on the warranty. But was forced to buy the extended because I don't know if its going to break down again. What can we do about these poorly made machines? My old machine lasted me 17 years and 2 moves before it dies!
I have the same problem with the F code and have to press stop and then start a couple of times to get the washer going. My machine is also 1 year old.
Machine continues beeping and lights keeps cycling on spin speeds, sometimes does not spin. Most the time pressing buttons have no effect. About have the time it will not spin and have to run thru comple cycle one or two times for it to work properly.
we are having the exact same problem with this model, ours is also one year old and we get the blinking F1 error code immediately and have to reset several times. Then the same thing happens with 17 mins left in cycle. This problem didn't start happening until miraculously just after warranty expired.
I have the same problem after sears replaced the sensor $200. The F1 same to occur during filling. I'm thinking it's a water pressure or water temperature issue. After you finally get by the 'F1' error, the machine seems to run fine.
