Question about Princeton Digital LCD17 17" Flat Panel LCD Monitor
LCD17 Flat panel
No display. Get slight flash of image for less than a second. I have traced the problem to the HV board which has a bad(shorted) driver on one side of push pull trans and would like to replace the board. It says on it: Sampo qpwbgl9931DLD. Any way? I hate landfils.....Gary
  • 944 Answers
Check this link; http://www.lcdpart.com/Products/qpwbgl9931dld.html They sell it for $69.99 and also list other alternative part numbers / manufacturers. Hope this helps, please ask again if you need more options :)
Posted on Sep 17, 2007
Hi I hv a toshiba smart tv it's two years old , it comes on but does not hv pic it does hv sound
if you choose the menu does it display menu items or is there no image at all? No image at all when you press menu would mean the backlight is likely not working and requires repair. If you do get menu items on screen check the image settings and ramp up brightness and contrast
Jan 14, 2016 | Toshiba Televison & Video
CS Code
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
Aug 29, 2008 | Amana RC17 Microwave Oven
My screen only flashes the akai startup screen and then goes black again
Could be several things,
you could have a faulty inverter, bad CCFL back lamp, faulty 24vdc circuit, or a HV short to ground @ inverter output
Nov 12, 2012 | Akai Televison & Video
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Soniq QSP422T LGEPDP might be a sustain board problem
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 12, 2017 | Televison & Video
JV50P has power but that's about all
if Vs is showing less than 1 ohm, that is your shorted line. it goes the sustain and address boards (big boards on left and right side of set) and one of those is bad. try using the same ohm check to see which is shorted and replace that board to fix the set. if it is the address board (one that plugs into boards with lots of chips addressing each horizontal line of screen) you need to check all the address buffer chips. make sure there is no little pin sized hole burned into one of these chips or it will blow out your new address board.
other names for boards
address = Y sustain
sustain = Z or X sustain
May 26, 2010 | Vizio JV50P 50 in. Plasma TV
Panasonic 50" plasma. A rectangular box from upper left, slightly different color than rest of screen. Then after 45 minutes or so the entire image turns into an Andy Warhol affect -- colors are reversed,...
This sounds like a bad logic board. On this model, Panasonic calls it the "D" board aka Format Converter, Plasma AI Processor. It takes the video info from the main board and processes it for the display panel. Repair is board replacement.
Apr 17, 2010 | Panasonic TH-42PX500U 42 in. Plasma...
Dead. External power supply is good 12V but monitor wont turn on.
my 12 power supply was only 500ma, not the 4a needed. Got the monitor to power up but now the screen goes dark after 2 sec. Looks like a bad backlight issue. I'll replace the inverter board.
thanks
Dec 08, 2009 | Princeton Digital LCD17 17" Flat Panel LCD...
LT 30 HV Olevia Syntax No picture - blue flash
Ur video converter board is dead.
Need to be change.
Aug 15, 2009 | Insignia 37" LCD Flat-Panel HDTV
Power up problem
http://www.lcdpart.com/Products/qpwbgl9931dld.html Have fun.
Sep 17, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Princeton Digital LCD17 17" Flat Panel LCD Monitor Logo
148 people viewed this question
Top Princeton Digital Computers & Internet Experts
Daniel Dollive
Daniel Dollive
Tom Chichester
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
