Question about HP iPAQ H3765 Pocket PC
Zenith big screen tv
Has no picture but it has sound
0 characters
1 Points
How do i correct the dark screen problem with Sony Experia Z (the Big Black version)
The white light sounds like it's gone bad. You'll have to replace the entire screen to fix it since the white light cannot seperate from the screen internally.
Jun 02, 2014 | Sony Ericsson Experia X8
Zenith problems
You have to contact WaMart only they can help you get the missing part.
Dec 21, 2013 | PDAs
A battery with a diagonal red line comes on my screen everytime I
Sounds like your battery isn't taking a charge. Not a big deal as long as you purchsed a protection plan when you bought it. Most cel carriers will cover everything but water damage if you bought the warranty.
Sep 07, 2009 | RIM BlackBerry Pearl 8100
Tv was on and it dropped on its face. the sound works but the screen is black
OUCH! This sounds like really bad news for you. It may be just a loose connection or it could be that the screen is totally ruined. Your best bet is taking it in for repair to see if it can be salvaged.
Aug 28, 2009 | LG KU990 Viewty
Viewing photos on the htc touch diamond.
If you take lower resolution photos on the Diamond, especially photos for contacts, they aren't as big as the other photos, so you must zoom in for them to fill the whole screen. For that, simply do a half circle clockwise motion on the picture itself.
Also, if you took larger photos with the camera on it's side, you must turn it to it's side again so the picture goes back to landscape mode.
Jan 12, 2009 | HTC Touch Diamond Smartphone
Need code for zenith TV
0017, 0016, 0092
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
May 11, 2008 | RIM BlackBerry Pearl 8100
Phone shows a call coming through but no sound
Taking the battery out to switch your phone ON/Off can cause serious problems.
To receive calls, your phone must be on.
This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you!
Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following:
• Press Phone/Send .
• Press Answer (left action key).
• If the headset is attached, press the headset button.
To ignore a call and send it to voicemail, press Menu (right action key) and
select Ignore or press the Power/End key.
Waking up the screen and turning it off.
Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
Feb 20, 2008 | Palm Treo 750 Smartphone
Green ready screen
I did a hard restart and it fixed the problem. Had to re enter all my info but has been good ever since. I tried just for kicks to put in the sd card again. Found that it must be to big of memory because it happened again. Thanks
Jan 16, 2008 | Dell Axim X3 Pocket PC
My backroud
On the rx3715, the background on the Today screen can be changed from Settings>Today. From there various themes can be selected and used. Also, if there is another picture I want to use as my background, I can browse and select it from the same screen.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ H3765 Pocket PC Logo
16 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
