Question about HP LaserJet 2420 Printer
Smudges down left side of paper
Hi, We have a laserjet that has begun to start putting spaced out "smudges" on the left side of all print outs. While they are not extremely dark, they do not look professional and we need this fixed. On a paper path test, the smudge appears a little before halfway down the page, right above that is one that is similar but indented and then about equal distance from the bottom is the same smudge and then again at the very bottom. What do I need to test to figure this out? We are starting to get multiple complaints and have to find a fix. Thank You, mtaffer
  • 82 Answers
Maybe something attached (corrector fluid or adhesive)on drum (green cylinder - don't touch it!) or more probably the fixing film on the fusing unit is damaged (probably some paper clip left over input bin, or trying to remove a paper jam with some sharp-pointed thing) If you have some other printer like this around, try with another print cartridge, if error persist , the fuser film is damaged...
Posted on Sep 08, 2007
HP 1600 prints with left side smudging
If you are ask printer paper Quality then first you check it ink label and then you check paper quality because both are depend which types of quality you are used. If one in dull then printer quality also dull. I share a print quality related link please read and follow instruction.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01691481
Thanks,
HP Printer Support
Apr 04, 2014 | HP LaserJet 1600 Printer
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
Put paper in the manual feed tray(tray 1).
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
HP Laserjet 1012 - Little smudges on page.
You probably have an excesive amount of toner building up on your rollers or fuser. A cleaning done by a certified technician should take care of this problem for you.
May 28, 2010 | HP LaserJet 1012 Printer
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
HP LASERJET 4250n
This problem is with the fuser. It needs to be replaced. They tend to burn out right in the center leaving a rolling smudge across the page as the unfused toner left on the roller gets printed on the next roll-over.
Jan 06, 2009 | HP LaserJet 4250n Printer
Blue smudging down left side of the paper and paper turning greyish color
check the fixing unit if the adjustment for envelop is activated or not the same. set to normal.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2420 Printer Logo
855 people viewed this question
Clive
Clive
