2005 chevy tahoe the hatchback door will not open. using remote keyless entry. is there a way to open from the inside? no key hole for me to manual unlock or there is but cant find...
I can say I have had the same problem, only the back doors and the rear hatch/glass won't open using keyless remote from them freezing this Winter. The front two driver/passenger doors will unlock with keyless remote but none of the rear doors, hatch or glass. Since I had to replace the stoplight bulbs in the rear with one not working and I don't need a ticket on Memorial Day weekend (need to replace 2 at the same time is wise according to any good mechanic), I had to get the rear hatch open to get to the lamp assembly and replace the bulbs. My thinking was that since my two front locks were opening but no others and my keyless remotes are working, it has to be a fuse or relay that is not working! So, I talked with a NAPA rep and he said the "Day running lights" relay can be a temporary fix to get the rear locks open to replace the bulbs. I looked up in the owners manual where both relay's are located and removed the "Locked" relay and "Day running lights" relay and put the "Day running lights" into the same slot where the "Locked" relay was not operating and it worked! I got the doors unlocked and replaced my stoplight bubs replaced. Now, I have a new problem, my Tahoe won't start!! I'm assuming the relay wasn't supposed to stay in the wrong slot when operating the vehicle because I started the truck, and it started and died-started and died-same and again. I think the wrong fuse can be used to fix another problem like a fuse. But, a fuse you can leave in and deal with one operation in the vehicle not working until you can replace the fuse later when you purchase it. But, not a relay! Now, I think the confused electronics cause another component (possibly the fuel pump relay) to burn out with the wrong relay in place of another when the vehicle operates. I should have known but I was so glad to get the doors open after two months and it being Memorial Day weekend. Now I have to find out what else is wrong so don't make that mistake to avoid the same predicament. Better to get the relay ordered and replaced than to have this happen to you.
Hi ,this is shenzhenelectronic.
we have some electronics ,for example Microsoft Xbox360 Live card 10000 US Points,Moster beats by Dr.Dre solo hd,Moster beats Dr.Dre pro and so on.
Welcome to visit our website
http://www.shenzhenelectronic.com/monste...
Moster beats Dr.Dre proHi ,this is shenzhenelectronic.
Moster beats Dr.Dre pro http://www.shenzhenelectronic.com/brand-...
Release and raise the rear hatch using either the unlock button on the inside of the driver's door or a keyless remote, locate the hatch release on the inside of the hatch, then depress the hatch pins using a flat-head screwdriver, and remove the hatch panel holding clips with the trim panel remover.
Remove the rear hatch release panel with your hands, detach the release cable C-clip with the flathead screwdriver, then carefully pull the hatch wiring out with your hands.
Remove the rear hatch release with the ratchet and socket.
doors and back hatch will not lock by the remote on the keys after i unhooked the positive side to reset the computer
