A soft reset will clear pending errors and bring your mobile to its initial state by restoring factory settings. To do this, the shortcut is: *#7380# This function apparently works on almost all Nokia mobile phones. Hard Reset It may happen that despite having restored your mobile to factory settings, the error still exists. In this case, it is recommended that you opt for a hard reset. Enter the code: *#7370# and press Yes to confirm. Important: You should back up any important information before doing this. To perform a hard reset on a Nokia phone that won`t turn on, press simultaneously these 3 buttons: on/off + * + 3.
there is a fuse behind the on/off switch but to get to it you need to open the top then the control panel with special tool and you can check the fuse there is another fuse on the bottom left corner of the unit behind the transformator. good luck
